Lighting set up ...thoughts?
magicaxeman
An Idiot
At the risk of being a royal pain...
I have been trying to work things out and so far your good advice has resulted in me settling for a speedlite based set up rather than continuous light.
The below diagram probably says things in a better way than I can, though its not to scale.
The background area is approx' 1.7 meters across, the camera position approx, 2.5-3 meters away from it.
Lets put it this way 85mm on a canon crop gives me nice head and shoulders shots, 50mm waist up for standing subjects.
The plan is to use a pop up type background (with train when required) and suspend it from the wall covering the majority of the wall area there.
I planned on lighting the background with a Di622 on low power with a small softbox attached in order to get the impression of separation.
The main light will be an interfit strobies xs kit, 580ex on a ettl lead to the camera, with the idea of adding a second speedlite later and controlling all via an ST E2.
The 60" x 40" multi reflector can be used to bounce fill light back in to the shadows or with its black cover used to kill light for hard edged shots for now but a second small soft box is planned.
Most subjects will be seated.
What I would like to achieve is some nice portraits of individual family members and friends, mainly black and white.
I guess my question is am I on the right track with how I'm thinking and with what I'm trying to achieve?
I should say for those that don't know that I'm stuck in that bed 24/7 so I have to try and make use of any space around me rather than find a nice location and use available light as I used to.
Sadly there's no way to fit anything that size in, I might be able to push to a 60cm softbox but thats about it really.
I felt it was better to have a small softbox rather than no softbox at all and am hoping only to have to use it to supplement natural light from the window rather than shooting in total darkness and completely relying on it as a light source.
Though I have no intention of doing full length shots, mainly head and shoulders, or upper body
