kman
kman said:....If its the lack of spread of light your worried as opposed to flash power would shooting the sb900 into a reflected brolly not sort it?....
Very useful stuff, thanks guys!
Bought some triggers now, just waiting to pull the trigger on the Lenscarta stuff. I would like to see it in person though before I buy tbh.
I'm glad you like it, comparing it's power and the quality of the light to that of a hotshoe flashgun is like comparing chalk and cheeseBought the Lencarta Safari Li-Ion in the end.
Did a quick test shot to get used to it and understand what power works when before a big shoot last friday.
So they are a bit of a ball ache to set up compared to my SB-900 as that was just 1 switch and it's on, but it's so worth it! being able to stand back with the flash and put it at a higher power means you can get a much better spread of light. The Batteries lasted the whole shoot without even blinking, but that was expected. I would have had to have changed the batteries in my SB-900 in that amount of time. Looking forward, I need a standard reflector as I don't feel the bulb is safe enough without something protecting it. Was kind of hoping it came with one, but at just £10 I'm not too fussed about getting it after. I am also thinking I'll get a strip softbox at some stage too and that's when it'll be a real test of power.
Bonus that the case (which I'm very impressed with) fits in the Mini too:
(rig stuff goes on the front seat)
Overall, very impressed![]()
You do need a reflector though, not only for protection of the flash tube but also to harness all that power and send it in the right direction. They are no longer included because a lot of people either don't want the standard reflector (they buy beauty dishes, high intensity reflectors, softboxes etc) or already have one.
The offer with the free bag was supposed to have ended before now but everyone seems to love them so the free bag offer will run for a bit longer, while we have stocks of the bags.
LOL.. you push a lead into the power pack and switch on... not too difficult
You really need to get some reflectors otherwise you're losing most of the light in other directions.
Hotshoe flashguns have highly efficient (mirror-like) reflectors to maximise effective output, this creates extremely harsh light.
What is the difference in light quality Garry
Thanks for that Garry, I wish I had asked that question last week. after playing with my first couple of flashes I do find the light is very hard, stark and difficult to get looking natural.
I find that with continuous light you can build soft light levels but with these flashes I just got, its all about compensating for hard shadows. To be honest, I'm not sure I like these flash's that much so far.
I think I need to try out a smartflash, based on what you have just explained, that light quality difference maybe whats missing for me.
Sorry OP,waffling on your thread.
So the actual light 'is' the same, just housed differently...![]()
Yes and no.All Garry is saying is that the larger the light source, the softer the shadows. And the Safari Li-on normally has a small dish reflector with a diffuser front that is larger than a bare hot-shoe gun.
If you fit a similar reflector or softbox/whatever to a hot shoe gun, and spread the light similarly, the 'quality' of the shadows and highlights will be the same, and any loss of light will also be the same.
Lencarta does not have magic photons.
Lencarta is no longer supplying that wideangle reflector with the diffuser, most people are better off with the larger standard reflector, which increases the effective power by 80% without the diffuser at a distance of 2m, and by much more with the diffuser.And the Safari Li-on normally has a small dish reflector with a diffuser front that is larger than a bare hot-shoe gun.
Thanks Richard, I wish i had listened to you earlier you know, I bought another couple of those Yongnou 560 11, flashes so I now have the TTL thing and three manual jobs and whilst its early days, and completely different to what I am used to, as a direct step up from my continuous setup, I bet I would have preferred the studio flash heads. Having said that I am getting okay results and learning a lot.
It'll be interesting to see how you work modifiers (like a strip box) into your shooting George and just what results you get, thanks to having oodles of power that won't get soaked up by diffusion. Is it just the one head you got?
Yes and no.
There's nothing magic about Lencarta, it's just that when there's enough power to go round a manufacturer can afford to fit a reflector that doesn't have a highly polished surface, and the reverse is also true - hotshoe flashguns do have highly polished surfaces, to make the guide number look impressive and to provide enough 'reach' for the flash.
And although it's true that fitting a larger reflector, a softbox or an umbrella to a hotshoe flashgun will produce a similar quality of light to that of a Lencarta Li-on (for example) and that the proportionate loss of light will also be the same, the fact is that if the light source doesn't have enough power to start with then spreading the light out over a wider area will reduce the effective power to the point where it isn't very effective - so that option doesn't really work well with a hotshoe flashgun in daylight.
I don't know how you shoot outside with portable flash (i know your an expert in a Studio) but i have no problems at all over powering the sun with a Hotshoe Flashgun or a "Quantum style Flash" when mounted in a 80x80 Softbox. Its all down to technique i believe![]()
Just done a Model shoot in the loverly Sun we have had Yesterday, and I wasn't even using the most powerful Canon Speedlight. If i had used the DL250 it would have been even easier with power to spare.
GFWilliams said:b****r
Anyone know how to fix this?
Has the locknut come undone, or is it broken?
b****r...
Maybe it's been around that Renault for too long and just decided to go all French and fall apart....![]()
As I've already told you, we will replace and fix it in our workshop
Think you might be right :bonk:I think that's a bit unkind on the French, some of their stuff is worth buying.Maybe it's been around that Renault for too long and just decided to go all French and fall apart....![]()
Interesting stuff.
I spent all yesterday with a car photographer. He doesn't use flash - everything is continuous light. He seems to do alright. http://www.ripleyandripley.com/
