HoppyUK
- Richard
- No
There's no logical reason why this couldn't happen. The interface between hotshoe and (say) SB900 is pretty complex. For one thing this is how you do firmware updates to the flashguns. For another, the camera definitely knows what kind of flash it has attached. The triggers I've tested with similar properties even fool the exif into thinking there's a speed light firing.
But it seems unlikely that Nikon would miss something like this. I guess it would also raise the possibility of Nikon tweaking their camera firmware to stop this trigger working.
Either way, if the independent reviews prove favourable I hope you have your IP lawyers on standby. It's sad state of the photography industry that if somebody invented something revolutionary like this then eBay would be flooded with 30 quid clones in a couple of weeks![]()
No trigger can affect the way the camera shutter operates, and it's not how firmware updates are done either - they go through a firware port. And I'm not the only one to see what's actually happening here, I'm just trying to explain the physics. I didn't expect to make any friends by doing so, but my IP lawyers are sitting comfortably.
At the heart of it, and what makes some of Lencarta's claims impossible, is the camera's focal plane shutter. As I told Garry almost three weeks ago, on here, a simple test with an an IGBT hot-shoe gun at anything less than full power will a) not work, as he has since discovered, and b) the explanation for that would reveal the true nature of the beast. Lencarta has not grasped the implications of why it doesn't work at anything except full power with a hot-shoe gun, which is fundamental.
At that time, Garry said he was going to do these tests, to explore the boundaries as he put it, and now we see the Mach 1N's instructions clearly state "Most types of hotshoe flash or other IGBT flashes must be used at full power." http://www.lencarta.com/mach1n_ins.pdf So Lencarta now admits the Mach 1N won't work with hot-shoe guns at anything less than full power, but has failed explain the reason why. What I have done is attempt to explain it, and it is simply this: with a hot-shoe gun at anything less than full power, the IGBT control cuts off the tail of the flash, and without a tail you get no exposure with the Mach 1N, because it's a tail-sync trigger. Case closed, basically.
What I would like to see, and it's hardly a difficult test, is this. Take a hot-shoe gun, in a darkened room so that the only light is from the flash, the subject to include a plain wall covering the full depth of the image at some point.
For starters, take a normal flash shot as a control. Fire the flash at full power, in normal x-sync mode, at 1/250sec. Adjust for correct exposure and note the settings. The exposure level will be high of course, with even illumination top to bottom, and good colour - situation normal.
Now engage the Mach 1N trigger and do the same, taking shots at progressively higher shutter speeds. The exposure will immediately become much darker, and will become progressively further under-exposed with every stop of increased shutter speed. Adjust aperture and ISO to restore corect exposure, and note the shift from the control shot. In addition to substantially reduced exposure, the image will be significanly brighter at the bottom and darker at the top, because the shutter is running down the frame in sync with the fading tail of the flash pulse.
Final check, Mach 1N trigger, hot-shoe gun at full power, shutter speed at say 1/4000sec, exposure correctly adjusted. Now turn down the flash power, to 1/2, 1/4, 1/8th etc. The frame will be mostly black.
Seriously, these tests can be done in 20 minutes and they'll be conclusive.
