Lee Landscape Polariser
sarahhj
Sarah
Hi,
Can anyone with the Lee Landscape Polariser kindly let me know if it is possible to remove the screws on the (Lee) filter holder, whilst the polariser is still attached to the adapter ring? I.e if the polariser becomes stuck on the ring, is it possible to remove them together from the rest of the holder. I've tried looking at photos online but none are clear enough to show if the screws would clear the polariser.
Many thanks!
Give me a sec, I'll go check it out for you.. ..
Right, I've just checked... the screw heads catch the polariser by a very miniscule amount, but enough to probably wear a very tiny bit of the polariser away after repeated attempts. Basically, I didn't want to go much furthur after is caught it. All four screws catch. I have taken a phone pic and will try to upload it for you.. .. hope that helps..
Moey!
Actually, forget that.. .. yes, they do catch, however, it can be taken off.. .. .if you lay the whole thing on a flat surface and unscrew each screw whilst lifting the polariser away from the filter system, eventually, the whole thing will lift away from the filter system lifting the screws out with it.. Basically, unscrew all four screws bit by bit instead of one screw at a time.. ..
Hope that makes sense.. ..
Thank you for your speedy and detailed help Moey! (y)
