Only an hour!
True, they're not a great idea and only work in theory. It would take a heck of a lot of time to make one of those that fitted the image frame
exactly.
The other problem, and this potentially applies to most regular lens hoods, is that it's very hard to get the inside surface absolutely dark black. Canon does it pretty well with velvet flocking, which is good, but if the inside surafce has any reflective characteristics at all then there is a danger that what it will do is simply collect more light and redirect it straight into the lens! There were some flarey images posted on here, some time ago now, which were puzzling because the supplied lens hood had been used. Turned out it was just plain black plastic inside, a bit shiny, and was actually making things worse.
That is why some of the best lens hoods have a ribbed inside surface which traps most of the light errant light, which is also the double benefit of using a bellows hood. You'll see them used all the time on TV and movie cameras - huge great things sometimes. But what is good about a black card rectangle in front of the lens, apart from being exactly custom sized, is that everything behind the card is in complete shade. Make sure the edges of the rectangle are matt black
PS If you get around to doing this, please post a couple of with/without images on a nifty-50. While I always do it with my own lenses for this kind of studio stuff, in all honesty my main 24-105L lens is just astonishingly resistant to flare and the difference is not massive.
