- The other Chris
you can never have enough tripods and bags, besides I think they are pack animals and get lonely on their ownToo many tripods?
If you have to carry them you can easily have too many.you can never have enough tripods and bags, besides I think they are pack animals and get lonely on their own![]()
Yes, and you can't have favorites, because the others will sulk.you can never have enough tripods and bags, besides I think they are pack animals and get lonely on their own![]()
What are the current ones? Fidelity? There are loads for sale on the ebay, i think with a lot of LF stuff you buy and test to see if it’s useable, you can still buy new ones for peace of mind but will cost youI devved four more sheets during my lunchbreak today. Two look fine (from glancing at the negs), the other two are beset by light leaks. One of the light leaks looks to be very similar to the one I had earlier and posted here: https://www.talkphotography.co.uk/t...y-group-from-zero-to-hero.504894/post-9269394.
The other one (from the same film holder) looks very similar to a leak that @ChrisR had in this post: https://www.talkphotography.co.uk/t...-acrylic-4x5-field-camera.636352/post-8295523
My initial assumption is that this particular film holder might be no good, so I'll probably avoid using that one unless I can rule that out as the cause.
I'll pop some scans up later when the film is dry and I've finished work.
Luckily the two borked shots are just of the local church, so I can easily shoot them again (and I'd only really shot them to practice and to give me four sheets to dev rather than just putting two in the Stearman tank).
Any suggestions for reliable sources of film holders (and any types to avoid)? I was going to buy a couple more in any case? Ta.
Yeah, Fidelity Elite.What are the current ones? Fidelity? There are loads for sale on the ebay, i think with a lot of LF stuff you buy and test to see if it’s useable, you can still buy new ones for peace of mind but will cost you
TOYO !!I devved four more sheets during my lunchbreak today. Two look fine (from glancing at the negs), the other two are beset by light leaks. One of the light leaks looks to be very similar to the one I had earlier and posted here: https://www.talkphotography.co.uk/t...y-group-from-zero-to-hero.504894/post-9269394.
Film holder and or spring back not sat properly prior to removing darkslide.Here's a phone snap of the two negs with light leaks.
Any thoughts as to the likely cause? The rebate doesn't seem to be showing signs of the light leaks - there's a bit on the portrait orientation shot of the church but it doesn't really correspond with the defect on the image.
The one on the left shares similarities with the light leak that @ChrisR encountered, although mine seems to have almost half the neg affected.
The defect in the one on the right is identical to the shot I posted here previously - the only difference being that the film had been loaded into the holders in a different orientation for each shot.
Hi. I’m happy to take a look at the back if you want to post it across to me. I’ll send you my address via pm.Hmm. It appears that the problem is on the other shots too, just not as pronounced.
I've taken a look at the camera and now think the issue is coming from where the camera back is attached. If I put a light source inside the camera I can see a very thin line of light, but it's from where the back is attached to the camera, not from where the film holder is pressed against the back. I've no idea how to proceed now short of contacting @stevelmx5 to see if it's possible to get a repair.
The amount of light visible through the gap is negligible, probably less than a 10th of a millimetre, which probably explains why the impact on the negatives is much more pronounced where I've shot in duller light.
The light is coming out from this arrowed area, although it seems more pronounced at one side, which probably explains how some of the light leaks are occuring down one half of the negative:
The circled area shows where a bit of the black tape surrounding the green acrylic looks to have been crushed slightly. I've no idea if this has anything to do with the problem though.
Although, looking at your negatives, I’d expect light coming in from the top to cause a lighter band horizontally across the frame, rather than one half of the image vertically?
If you want to send the whole camera instead, I’m happy to take a proper look at both the film back and body.Thanks Steve. That would be great. Happy to provide as much info as I can as to what I’m noticing.
I’ve popped a light inside the camera this evening (a phone with the torch switched on) in a dark room and can see light emitting from where the back attaches to the camera. It’s more noticeable at the top (with the back in portrait orientation, or from the right side in landscape), but I can see a little light escaping at the sides too. To be clear, it’s a razor thin slice of light that can only be seen when you look at it from the correct angle, but it’s there. And I guess that if I can see light coming out, the film will see light coming in.The simplest way to identify if there’s a light leak when the camera is setup is to go into a dark room and point a bright torch (I usually use the one on my phone) into the front of the camera with the lens/board removed.
You can also reach into the front of the bellows with the torch and point it directly at the rear standard, moving it all around, and any leaks will be pretty obvious.
As well as saving film, using this method is a much harsher test because it’s very rare that you’ll have such pinpoint direct light hitting the camera from multiple angles.
I made quite a lot of changes between the early acrylic Kickstarter cameras and the latest ones I built last year, so I’m sure I can get to the bottom of any issues on your camera.
Sorry this is happening, Nige. I've been relieved seeing your successes so far that you hadn't had the problems I had, assuming these were my user error.Hmm. It appears that the problem is on the other shots too, just not as pronounced.
Thanks Chris, appreciate that.Sorry this is happening, Nige. I've been relieved seeing your successes so far that you hadn't had the problems I had, assuming these were my user error.
The two suggestions from subsequent posts to the one of mine you referenced earlier were to keep the back pressed against the camera with a thumb (etc) while withdrawing the dark slide, and/or leaving the dark cloth draped over the back of the camera while the dark slide is removed. I looked for and didn't find a light leak in the actual camera body (and IIRC so also did John @thedarkshed, who had a Chroma and was much more knowledgeable than me).
If there's a problem with the camera itself, drop me a PM (if that's the correct approach) and we'll see if we can get it sorted.
Unless in a desperate need to have numerous sheets developed quickly for clients , I really do not see the benefits of souping so many in one go.![]()
What's next: SP-645, SP-8x20, Bigger and Better...
SP-645 The original SP-445 wasn't even in production and people were asking for a higher capacity version! We had requests for systems that could process six, eight, ten and even a few asking for twelve sheets. Anything past eight gets really complicated, really fast. Even an eight sheet version...shop.stearmanpress.com
Stearman back with a 6 sheet tank now by the will of the people
Do you not get issues either loading the mod 54 or the sheets coming adrift and sticking to each other during development?I do 6 at a time quite often with my Mod54, it allows me to unload my Grafmatics in one go.
The 8x20 looks tempting for me personally, although I get by with using my 8x10 and Paterson Orbital at the same time.
I was never at ease with the system tbh
I would say this is a mod54 specific issue, the stearman you have a rack per sheet so great reduce the chance of an issue - their 1st gen holders needed work and now on gen 4 ppl seem to be very happyDo you not get issues either loading the mod 54 or the sheets coming adrift and sticking to each other during development?
Yeah he’s an ok bloke that @stevelmx5I shot a couple of sheets of HP5+ this morning, the first time I've used my Chroma since @stevelmx5 very kindly took a look at the camera and resolved the issue I was having with light leaks. The good news is that the two shots I made today show no signs of leaks. It was foggy and the light was dim, but I think I would still have seen leaks were there an issue, so it looks like I'm back up and running. Thanks Steve, absolutely marvellous service!
The shots are nothing special - tests more than anything and I was rushing as I had to get to work. The top of the willow tree is a little out of focus, and I'd have preferred the foreground rather than the background to be sharp in the picture of the bench, but this is what happens when you don't take your time I guess. Looking forward to shooting some more and spending more time getting things right.
Foggy willow by fishyfish_arcade, on Flickr
Frosty bench by fishyfish_arcade, on Flickr
Lol, thanks for the glowing praise
Glad it's all sorted for you Nige, happy to helpI shot a couple of sheets of HP5+ this morning, the first time I've used my Chroma since @stevelmx5 very kindly took a look at the camera and resolved the issue I was having with light leaks. The good news is that the two shots I made today show no signs of leaks. It was foggy and the light was dim, but I think I would still have seen leaks were there an issue, so it looks like I'm back up and running. Thanks Steve, absolutely marvellous service!
Church of St. Mary the Virgin, Beighton by fishyfish_arcade, on FlickrYep my last exposure gave an image that was wonky on the negative.In a new installment of my ongoing (and unintentiona!) project "How can Nige mess up his large format photos", we have this...
Somehow, both these sheets are wonky. Looking at the negatives I can only assume that I've not loaded them into the holders correctly - in a way I didn't even know was possible! It's not happened on any of the other sheets that I've loaded myself. Anyone else had this happen?
It means the second is now unusable (despite it being otherwise ok) as the top of the church is cropped when the negative is scanned, and even more so if I rotate it in Lightroom. I'll make sure I don't frame things so tightly in future so I can at least have a chance to save the picture should it happen again.
At least the other shot was easy to save due to the framing being a bit wider. And still no light leaks, despite the camera being in full bright sunshine for the second picture. I wasn't particularly concerned that there would be any leaks after Steve fixed it, but this was a good test.
It’s too flipping long to list !!Edit, can you still not get the second scan if placing the neg direct on the scanner glass instead of in the dedicated film holder ?
Checklist for average filmie Tog:
1. Wind on film to next frame
2.Compose shot
3. Set aperture
4 Fire shutter
Checklist for Nigels @FishyFish LF outings:
I have to ask, do you by any chance reside to the west of the church ?!!!It's the local church
