Glad it worked Andy!
I should add that I did advise that it was marginally risky to do this with a lens. It only works if the lens barrel shrinks more than the retaining ring, and this depends on the materials. Also, sticking it in the freezer risks the barrel shrinking and cracking the lens elements. For anyone wondering whether to do this or not, either find out what materials the lens is made of first, or start with the fridge![]()
I don't think you can go wrong with Miles.
mwcamerarepairs@gmail.comAs I suspected, has anyone got his email address please.
Yep, miles is who I'd go back to. He serviced the shutter that came in the 65mm lens I bought from eBay. It had practically seized and the shutter speeds were all over the place. Came back in perfect working order. I'd happily send him more business.
2015-12-22_10-01-12 by Steven, on Flickr
Light leak, again... by Steven, on FlickrI might be asking a stupid question Steve but why would a light leak make a darker line on the image? That looks more like an area that underexposed rather than overexposed. I take it there's nothing stuck inside the camera blocking that part of the the film is there?
2015-12-22_11-31-33 by Steven, on Flickr
2015-12-22_11-31-55 by Steven, on Flickr
The two artifacts are not the same shape, and given that the notches are in the same place, you can't really conclude anything yet until you can reproduce at least one of the effects. The dark line in the bottom sheet (as we see it in these images of the sheets) is definitely an exposure of some kind. The bright line in the top can only be caused by a developing issue or significant under exposure. It would be very interesting to see if either of these can be reproduced, as that will a) determine which was more likely to be a random one off issue, and b) help to narrow down the possible causes. After all, being that they are not the same shape, the two corresponding locations could simply be coincidence?
@steveo_mcg If it's any consolation, you're not alone trying to locate light entry not that I can throw any light ( sorry couldn't resisit) on how to resolve your problem.
Nothing like as severe as what you're up against but frustrating nonetheless:
There are days I consider jacking in the LF gear.
There are days when I consider packing photography in altogether ........But I know it would be a huge regret.
Keep at it Steveo, frustrating at times and darned right dissapointing when a shot gets scr***d up, however when you do get the result you want, it is soooooooo satisfying, is it not?!!
I am in the process of making a lens board for my Sinar, it's 139 x 139 x Copal #0. it has various thicknesses to accomodate the light trapping around the edges, max thickness is 5mm. So I am using aluminium sheet 6081 5mm thick, aerospace grade to get the stiffness.Thank you Stephen, this is very helpful.
Cheers Dean, I'll let you know in a bit.
On Nick, how very childish.....![]()
I'm very new here but I want to ask for some help in deciding what tripod and head I should buy. I have a Sinar F2 which has been happy on Manfrotto legs. But recently they have performed like the classical rolling drunkard. I now feel the need to modernise as designs and thoughts have moved on over nearly 25 years.
It seems that Gitzo seems to be the name to conjure with and putting an Arca Swiss head on can provide a good firm support. I have looked around and talked to a few people and all agree with the Gitzo/Arca route. Price of course has a big influence.
My thoughts are to go with a combination based on the GT5532S Tripod, @ nearly £750 ! and the Arca Swiss D4 @ nearly the same price.. There are several options/combinations in these products, but as might be guessed I like to buy the best I can afford and then stick with it until it starts to fall apart.
I am hoping to tap into the experience of the group and your suggestions and comments are most welcome.
Just to complete my tripod request - in the end I bought a Gitzo 5532LS. I knew this was a sturdy option but when it arrived it exceeded my expectaions.
Saw a post that Ilford are offering their annual "Ultra Large Format" order opportunity... apparently it includes 5*7 as well as much larger sizes...
You may have a 45DX (as I do) which is wooden; the 45D is (if I'm correct) a metal technical camera rather than a field one.
