Professor1991
- Anonymous
Hi All,
I recently came across this device on kickstarter. Essentially the unit (Which is essentially a power brick) backs up photos on your phone while it charges. Their is no on board storage but their is a secondary USB slot for plugging in USB flash drive/ external hard drive so while your phone is charging, your photos on being backed up onto external medium. Their is also an app which manages the file movement.
The unit also has a MicroSD slot and after inquiring with the creators, it transpires you can you backup whatever is on the MicroSD card onto a USB drive/ external HDD. This explicitly wasn't mentioned in the bio (unless I overlooked it) so I figured it was worth asking. Whilst it doesn't have a slot for a full size SD card, it supports MicroSD so for all those photographers who use them to shoot via an adapter, is this something that intrigues your interest ? I understand many people are often looking for various means of backup and USB flash drives are fairly easy to come by so depending on your configuration, this could be a fairly cheap offline backup solution.
Thoughts ?
https://www.kickstarter.com/project...-backup-and-usb-port-for-iphone-ipad-android/
Thoughts ?
