I shoot raw and consider myself an real amateur. It gives a lot more flexibility in editing and you can always convert it to jpeg. Why limit your options?
It's only limiting your options if you're struggling to get the final image to your / your clients taste. The end result is an image file, if shooting jpegs only and you are having to rework/edit the image to a reasonable degree to get the image right, then raw is a better option as it holds more data for you to work with. If you only need a minimal amount of pp edits then jpegs are fine.
Modern / most cameras are quite good at getting good images, but the fact is that you need to know how to get the best out of it to produce a usable image.
I can get more miles per gallon out of my car than my wife can, it's the same car doing the same thing, the difference is that I know how to drive it more economically. (or it's the fact that she weighs slightly more than me)
