- Anton
Everything this, the DoF is so different.
Larger sensors generally yield better (shallower) DOF
That could also be a trap...have you ever shot Canon's super yummilicious 85/1.2 at f/1.2?
One thing that stood out very clearly to me when I moved to full frame was how, when shooting a kids footy match, the players had much more separation from the background. This was using the same lens as on my crop frame camera.
But wider apertures cost a lot in weight and ££sOf course that would happen if you used the same lens in the same way. The interesting question is whether that would have happened if you'd used an appropriately different lens, e.g. shorter focal length and wider aperture.
Other than "because we can", please tell me again why an f/2 or f/2,8 lens is so much better than an f/4 lens in this day and age where ISO settings look like telephone numbers?
Shallower DoF at maximum aperture. Possibly marginally sharper at the slower lens's maximum aperture. Bragging rights!
Pros:Other than "because we can", please tell me again why an f/2 or f/2,8 lens is so much better than an f/4 lens in this day and age where ISO settings look like telephone numbers?
Film days, fair enough, I can understand that it made the difference between getting the shot or not at times...
I thought the whole point of photography was to 'create an image' not just record a scene.Other than "because we can", please tell me again why an f/2 or f/2,8 lens is so much better than an f/4 lens in this day and age where ISO settings look like telephone numbers?
Using a 35mm 1.4 at 1.4 and ISO 1600 will produce a completely different image than using an f4 zoom at f4 and 12800. It doesn't matter how 'good' the high ISO image is, it's a different picture.
I could also use 400 ISO and add some light, again the IQ would be fine but the picture will be different.
Better?Other than "because we can", please tell me again why an f/2 or f/2,8 lens is so much better than an f/4 lens in this day and age where ISO settings look like telephone numbers?
The real difference is what type of photography you do. When I buy a lens, I take no notice at all of the max aperture as I am unlikely to ever drop below f/5.6 and even that wide is an adventure for me. F/8 was invented for a reason.I thought the whole point of photography was to 'create an image' not just record a scene.
It took me a long time to realise that as wide aperture lenses get marketed as 'better' without 'better' ever being defined. While Phil is right that the aperture changes the resulting picture, not all those other possible pictures are desirable for all if us - they are not for me and not, I suspect, for Anton.
I was answering your post.If there is a point to this I do not get it, sorry...![]()
How much really, possibly and EXACTLY!!![]()
Given your talking about depth of field and not light gathering ability F8 dof is only F8 dof depending on what camera system your discussing. F8 on 35mm isn't F8 on crop (for dof) It's F5 on a crop camera and F4.5* on a canon crop camera.The real difference is what type of photography you do. When I buy a lens, I take no notice at all of the max aperture as I am unlikely to ever drop below f/5.6 and even that wide is an adventure for me. F/8 was invented for a reason.
Depth of field is not the only concern. Each lens has a 'sweet spot' and, together with depth of field, I want that sweet spot. That does not depend on sensor at all. I also did not say I always shot at f/8, just that I rarely shot wider - lenses go a lot narrower!Given your talking about depth of field and not light gathering ability F8 dof is only F8 dof depending on what camera system your discussing. F8 on 35mm isn't F8 on crop (for dof) It's F5 on a crop camera and F4.5* on a canon crop camera.
*ish.
You'll be well into diffraction by F8 on a crop sensor though so if you rarely shoot wider you'll be missing out on that sweet spot.Depth of field is not the only concern. Each lens has a 'sweet spot' and, together with depth of field, I want that sweet spot. That does not depend on sensor at all. I also did not say I always shot at f/8, just that I rarely shot wider - lenses go a lot narrower!
NopeYou'll be well into diffraction by F8 on a crop sensor though so if you rarely shoot wider you'll be missing out on that sweet spot.
No I didn't. I said the sweet point of my lenses was f5,6. I didn't mean to say sharpness deterioated significantly at smaller f-stops. I have a print from my 12/2 samyang taken at around f16. It's a little soft when inspected but not screamingly so and not noticeable when just looking at the pic.@chris malcolm
@soeren
I can't help but think we are saying the same thing. You've both said diffraction starts earlier than f8 and I said your well into diffraction by f8.
Yes it is lens variable and yes whether your eyes can see it or whether it's test chart only. Fact remains f8 on a crop camera isn't the sweet spot and that was my point.
I personally think aiming for a lens' sweet spot is a bizarre way of making a picture.Depth of field is not the only concern. Each lens has a 'sweet spot' and, together with depth of field, I want that sweet spot. That does not depend on sensor at all. I also did not say I always shot at f/8, just that I rarely shot wider - lenses go a lot narrower!
In fact other than in forensic imagery I can't think of an actual use for knowing the sweet spot of a lens.
Hmm studio portraits? Landscape detail kind of shots where sharpness and detail is of important but dof is not? Architecture?I personally think aiming for a lens' sweet spot is a bizarre way of making a picture.
Wow, thanks guys, some really good useful information and advise you've all given me. Some of which I hadn't given that much thought too like the handling and ergonomics of the body. I know they are larger and heavier but hadn't thought about the handling. I will try before I buy.
I just want to make sure that I make the correct choice before parting with my hard earned. It's not so much a desire to have the best gear, but after 40 odd years of taking pictures I still want to continue improving my photography and don't want to make the wrong choice. The money is not so much an issue as I will have to save up anyway, but just want to ensure I spend it wisely.
I'm in no rush, so I will do my homework first, and no doubt I will let you all know what I decide and of course post some of my efforts on TP
Thanks to you all
Doug
PS Keep the advice coming.
I've always said a D700 with 12MP is more than enough resolution.
I stand by that comment today.
In fact I know pros who are using them.
In fact I'm seriously thinking of going M43 due to the weight of my bag, my back won't stand it any longer.
So may go from my Canon 6D kit to Olympus.
I'll try one first to see if it gives me all I need though.
The ONLY reason to get a full frame now is to say you have got one, the wide angle thing has been beaten by modern lenses, fisheye and super wides are available for crop cameras that are exquisite and way better resolution than actually required FOR ANY JOB.
An analogy would be the 70mph limit and traffic congestion - what the hell use is a Ferrari F50 or Maclaren F1? They are still stuck in the traffic jam or limited to the same speed, so all that engine is completely wasted, it is just burning more fuel, and barely using 50hp of its available 800hp to trundle along at walking pace in the queue....the number of opportunities (jobs that actually require) the full capability are so few and far between and so limited to the top 6 photographers in the world......
Just an observation from someone who is a bit more down-to-earth than the majority of the sheeple who have to chase the latest gadget just for the sake of it. Having a nice camera is nice, but there are now VERY NICE crop cameras that are as close to the equal of their full frame counterparts it isn't worth worrying about. Take into account the very considerable size and weight penalty of a full frame system too - my Fuji OUTFIT weighs the same as the D4s with 70-200 only. I have gone from lugging around about 18kgs of kit to each job, to about 5kgs.....that alone is worth its weight in gold!
D700's are amazing cameras! I used one for a while but the Canon is too deep in my blood...which is why I am buying another 5D 1...and hoping to collect a few more over time.
Keep an eye on the classifieds if you fancy a mint 6D soon.
I've a feeling I'll be chopping it in the MFT stuff if all goes well.
