Colour Infra Red Film Effects.
This technique simulates the effect of Kodak colour infra red film.
Foliage tends to go red/magenta on this emulsion. Below is a shot on REAL infra red film.
This can be simulated well on a similar kind of colour image that again contains leaves, trees etc.
The first thing to do is convert the image into CMYK. This technique
will not work in RGB. (image > mode > CMYK Color)
Once in CMYK, we need to copy colour information from one channel to another. Select the Channels palette, and then select the Yellow channel.
Press command +A (ctrl+a on a PC) to select the whole image for the yellow channel. Copy that channel by pressing command+C (or use edit/copy). We then paste this into the magenta channel by selecting that channel and then pressing command + V to paste it into the magenta layer.
Then select the CMYK channel.
The image should now start to look like a colour IR shot. We still need to tweak the image slightly using the channels mixer.
Select the channel mixer from the layers palette window as shown above.
Once the channel mixer is open, adjust the Cyan and Yellow channels as shown below.
Pay no attention to the value warning that will appear after adjusting the yellow channel. The colours are meant to be out of kilter here….We’re simulating quite a special effect.
The image should now start to look very close to a real colour infra red shot. However, if skin tones were present in the image (like the one used here) then we may have to restore skin tones by using the
history brush.
In your history state window, click on the history state where the
image was first converted to CMYK (see below).
Then we can “paint” the original skin tones back in using a history brush. The history brush is located just below the normal paintbrush in the tools palette.
The last thing to do is convert the image back to RGB before any
further editing. Doing this will flattern layers, and PS will warn you
about this. To avoid the dialog, flatten the image first, then convert
back to RGB.
Finally, do a curves adjustment later if any excess yellow still exists.
You should now have an image like the one below.
IR film tends to render people's eyes as black... this can be added yourself if required.
