Interfit 182 ex150 flash heads
krystle
krystle
Hello,
I recently bought int182 ex150 flash kit, with an infrared unit to trigger the flash, howeva the infrared unit has more misfires than actually setting of the falsh units.
How can i fix this? please help.
Would buying interfit 412 single channel radio system work?
I have two lights and need both to fire at the same time so if i fit one reciever to one light and bought another reciever to go onto the other light would the transmitter then set both of together?
Please help!
krystle
Buy some cheap triggers like the Yongnuo RF602s or the Hahnel jobs in Jessops. The RF602s are cheap on a certain auction site etc the jobs in Jessops are about £60.
yes it will trigger the other. As the transmitter will trgger the recievers if they are both on the same frequincy and the same channel.
Though of course there should be an IR reciever built in...
EDIT: you may have problems getting them for your sony as they still use the strange old hot shoe.. Check that they will work with Sony before buying..
Would the Yongnuo RF602s or the Hahnel jobs in Jessops connect to the int182? I am now using a nikon d5000 just havnt updated it yet lol
On the back of your heads do you see a Sync socket? Either large or the small jack socket? If so then yes they will.. may need to buy a sync cable though..Not sure if they are supplied..
