It was my fault really. I'm still quite new to drawing up models in Sketchup for 3D printing. Whereas they look fine as a 3D render, once they go into the slicing software for the printer, any slight errors where the sides don't join fully or aren't completely flat on an axis will lead to holes in the mesh and a failed print. I'd drawn the parts as I went along, adding details and shapes but they hadn't all closed properly and it was a nightmare trying to go back over the parts to correct them. By starting again I could draw the main body in 3 sections (2 sides and base) which were closed up individually and checked as I went along then finally grouped to make a single piece.
Why do people take such awful pictures when they're trying to sell a camera and also not even bothering to clean the crud off it!
http://www.ebay.co.uk/itm/Instax-Mi...384042?hash=item2a698b9dea:g:16sAAOSwnNBXU0ss
I've sent them a question asking to see example pictures from it and also asking how they've fitted the back as I reckon the focus will be well out but they seem to be skipping around that..
Thanks. I suspect there are quality checkers for that. But I also suspect you'll want to tweak it as you go along from now on.
Edit: This looks interesting https://extensions.sketchup.com/en/content/solid-inspector
I wonder if the buyer will ask for some of his money back now there are more than one!
More adjustments to the InsTLR setup and testing. by Steve Lloyd, on FlickrThe infinity symbol (∞) looks like an 8 on its side so you could say it's working as intended.... around 1' at the closest focus and 8' at 'infinity.
Hi, Stevelmx5, you did such a good job on the conversion, i am trying to replicate that as well since i love the design of the TLR so much. But i have this question in mind that it confuses the heck out of me despite hard facts on the internet.
http://www.thephoblographer.com/2016/05/27/hacking-bronica-etrs-shoot-fujifilm-instax-film/
The instax pictures in the above link doesn't contain black edge as big as yours although being a 6x4,5 camera, the image it can cover is supposed to be smaller than your TLR a 6x6 ? or is it not?
According to this link,
http://www.kenrockwell.com/tech/format.htm#120
6x4,5 will cover 56 x 42 mm image whereas 6x6 will cover 56x56 mm. So the black bar in your instax image will be 4 mm in total? since instax mini is 62mm long.
How on earth can a hacked TLR sold on internet cover full frame instax image when it's maximum image cover is 56 mm? unless they change the lens?
regards
This is wonderful, great stuff!
