Hi,
If you do a web search on this you will find a you tube video with somebody explaining how it can be done. I was interested if anybody had tried this out and if there was any problems, bugs etc.
Cheers
James
I don't know if this is in the correct section but has anybody out there tried to set up an Imac to run Windows on an external (USB 3) hard drive? Any advice would be appreciated.
James
if you try and install windows 7 on a USB drive you will more than likely receive the error "Windows 7 cannot be installed to a USB partioned Hard drive".
you can find ways around this but i wouldnt like to. even with USB3 hard drive its not going to be a patch on internal SATA (CPU overheads yadda yadda) and i would imagine pretty buggy.
speed isn't the problem booting over usb 3, it's the latency
it'll be both. youll never get the same performance.
your suggestion of programs on the external drive is best. or create a VM with the image on the USB3, again its not going to set the world alight though.
