specialman
- Pat MacInnes
Spiritflier said:......Canon's glass is so much nicer (although I'll admit that that's a subjective opinion)....
I think the key difference between the two brand's lens range is that on face value, there's more modernity in the Canon range because they all meet a basic spec of all being EF and therefore based around built-in motors. I've read many threads about potential Nikon users being confused and sometimes put off from going with Nikon because there's still a real mix of lenses that are either AF-D or AF-S and then with all these other affixes like DX, ED, G etc. It's not hard to understand once you look at the glossary on the Nikon site, but Canon's is more accessible, partly because there is a much wider range across more key price points, plus there's a distinct 'pro' range in the L-series lenses*. Okay, they have some AF-S lenses that throw a small cat amongst the pigeons but nothing as confusing as Nikon's
However, I think that with its massive leaps forward in aiming for market share in DSLRs, there has to be some large-scale up[grade of glass at some point to bring lenses up-to-date. We now have a 'G' 50mm f/1.8 and there are some really exciting and useful lenses in the Nikon range, but there are still oddities that many see as just being plain weird; 200mm f/4 macro being one. Supposedly a brilliant lens but because many people are 'conditioned' to believe that f/2.8 is the holy grail in terms of zooms, it's looked on as too specialised and old fashioned, not helped by the AF-D focussing system.
There is a general theme that Nikon needs to 'do a Canon' and bring out a range of 'budget' pro lenses that ape lenses like the 100-400mm, 70-200mm f/4 and 400mm f/5.6. In some instances I think that true - a 400mm f/5.6 would be great teamed up with a modern body that can quite easily make up for a slow maximum aperture by having very high ISOs to call on. Plus, Nikon lenses do seem expensive, especially when you're buying AF-D technology. Another point is that unlike Canon, not every lens in the Nikon range can be used in AF mode on every Nikon body.
That said I have more faith in my Nikon lenses performing in all conditions than some canon lenses. I shot Canon for a decade or so and although the lenses were good, they never gave me that feeling of workmanlike performance and ruggedness that my Nikons give. That is of massive importance to me. I don't mind certain sacrifices (AF-D as opposed to AF-S for starters) if that lens will just keep on going forever and a day. My 60mm macro is a prime example of that; I've never once felt that a spot of rain (or whatever) would phase that lens, whereas I had loads of problems with Canon's 100mm macro, seeing a couple dying on my out on shoots. Yes, these are isolated examples and it's not a watertight argument at all, but I believe as a pro, I need to feel confident that the camera and its accessories will work without hesitation. I feel that way with all the mid-to-top end stuff I own from Nikon but can't say the same of the Canon kit I've owned, not 100 per cent anyway.
Anyway, I digress
*Nikon has its 'gold ring' lenses but there's much less said and written about these as a higher level of lens in the same vein as L-series glass.
