Idea for a shot....will it work?
kennysarmy
Yeah but can your army do this?
Jeff
Planning something for my 52 photo this week....cant say exactly but basically my plan is to take a self portrait in my garden once it goes dark.
Camera will be tripod mounted, 40d + 70-200
I will be a few metres away side on for a head and shoulders shot.
Going to mount my 430ex on a tripod and have it directly in front of me.
Flash will be fired using my cheap triggers so will have to set flash power manually.
I want no ambient light so intend to go manual at 1/250th
Confused as to what f stop to set or will it not matter?
As you are using the flash on manual, you will need to take a light reading with a meter to determine the aperture....... or do some test shots and chimp :D
You could also calculate using the flash guide number.
yes flash will have to be on manual as my cheapo wireless triggers do not support ettl...
i was thinking of starting off with flash on 1/4 power and f/5.6 - no reason - just a guess :)
I will have the advantage of also being able to move the flash further away or nearer to me....
Half the fun is seeing what happens isn't it??
That's quite a back garden !! :D
Nice result tho.
I really like that! The ambient is spot on I reckon. Could you have pumped up the flash power a little maybe? You look a little dark, would be good to see a little bit more detail.
I want to get out and have a go now!
Edit: Added you as a Flickr contact 8)
via TP Forums for iPhone
