srichards
- Suz
The carpet beater thingy died in my bissell lift off bagless a while ago. It's the best hoover I've owned. Now the cylinder bit which I was using has now packed up! I'm fed up as the Vax cylinder I bought to replace it a few months ago is utterly useless in comparison. It's much harder to empty (the bissell is one flick switch and the whole tub comes out with no nonsense). The vax has some stupid button system which makes it hard to remove off the top. Then you have to press a button on bottom bit which makes the lid open and all the crap stays in side so you end up pawing rubbish out of the damn thing into the bin which kicks up endless dust. The sole advantage of the vax is that it is easier to get to the carpet beater thingies and remove all the hair. I have long hair and it does a fine job of winding its way around all rotating parts and jamming them solid. If I forget to cut it out often enough then it knackers hoovers. Cylinders are utterly useless as they don't cover much carpet and the stick on fuzzy things fall off and they can't remove hair at all. A cylinder with a motorised doodad which is easy to keep hair free is a possibity but I generally want to cover areas of carpet with something with a bit of oomph. Dysons are out for this reason. The only one I used was pathetically weak and over priced. It had all the suction of a 10 year old hoover with a half full bag ie practically none.
The real annoyance with the bissell is that if you use the cylinder on its own it constantly falls over. I think this has what has done it in
Saw a large orange spark and smelled burning and it now won't switch on
I'm after a hoover which is bagless and easy to empty. No farting about pulling bits out, pulling out hair and cat hair. I just want one that is unclip and tip ie as easy as a bag! Washable filters are better and less bother otherwise you spend a fortune on replacement ones all the time. A HEPA one is preferable and the HEPA filters are usually just replaceable. Those only usually need changing every 6 to 12 months so I don't mind that.
The bissel is also good because it is a cylinder and upright together so you can split the weight. A light upright which has a decent long hose on it (fnar) is what I'm looking for as Bissel don't sell the lift off one any more.
It's spider season so I need to get round all the dark corners and hoover the little gits out of them.
The hoover power I'm looking for is the sort that you can feel gently lifting the carpet as you hoover. If it can't manage that then it is too weak for me. The vax is actually quite powerful but the idiotic emptying is the problem.
This one (ironically from Vax) is a potential if it's not a fart to empty: http://www.vax.co.uk/vacuum-cleaner...ers/power-9-total-home-upright-vacuum-cleaner It's also rather heavy.
Anyone got one or know of a decent bagless upright that isn't a pain to empty?
