steveo_mcg
- Steven
When you order one from a lab that has a drum scanner!
That's me told
Given the cost of scanning from some of the labs I kind of assumed they were drum scanned.
To those that do scan themselves, what do you use and what is the quality like?
- Obviously things can go wrong, but overall would you say its fairly easy to process negs (its a bit like following a cooking recipe)?
- Have seen some great reviews on the Epson V500 scanner. How would this compare to getting them scanned by Ilford/AG etc... Are there any cheaper alternatives, or is this going to seriously affect quality?
- What is the typical cost (in terms of chemicals and consumables, excluding initial investment) in processing own 120 & 35mm?
i thought i would give some different chemicals a go for a change so got some Ilford ID-11 developer, Ilford Ilfostop and the Ilford Rapid Fixer.
Just looking at the fact sheet for the Ilfostop it says the time is 10 seconds! That just seems a bit quick. By the time you pour it in , youre pouring it out.
Does anyone else use Ilfostop and can confirm that?
No mentioning of red light here. Is it not necessary anymore to process Black & White photos? Please advice.
For 1+100 Rodinal, if your tank holds 300ml, you add 3ml of Rodinal to 297ml of water
Isn't that 1:100?
(I know it makes no real difference, but both are used interchangeably - which is a bit silly)
If you can measure out 297ml of water accurately then you're right![]()
One litre , 1000ml, weighs 1000g so just weigh out 297g on your kitchen scales. That's what I do, never had a problem.
I know it's being picky but the weight of 1 litre of water is 1kg but isn't the specific gravity of developer higher? So not just a simple equation of 1g = 1ml or vice versa.
I may of course be talking out of my arse, I'm sure somebody terribly cleaver will be along soon to tell me so![]()
Isn't that 1:100?
You could try and pick up a Paterson Orbital. It uses so little chemicals that I would happily just develop two 4x5 sheets at a time ( it will take a max of four 4x5 sheets). So you you only need to save up 2 of your N. N+1 etc. negs and process them this way.does anyone do their developing in the dark in trays? I was thinking about this last night. I want more control over individual neg's and having to do 6 sheets at once wont let me do that. There's no point adjusting exposures for a scene if you end up lumping everything together in a tank.
So i thought of setting up some trays in the bathroom to do single sheets at a time. Just wondering how many sheets you could put through the chemicals before the soup gets used up. Could i still use Rondial 1 shot or would need something a bit stronger if i'm putting several sheets through it over time. Does the red light thing only apply to printing, developing the negs still has to be done in the dark?
I just use my kitchen scales. I know dev and water have different densities but in the quantities being used it makes next to no difference.
So, I've read through this thread... the basic instructions seem clear enough (*), and the couple of utube videos I've watched make loading the spiral seem more doable than most descriptions I've read. But there's one bit of black magic that doesn't really get explained AFAICS. It is... what chemistry to use? I see mention of Rodinal, ID-ll, TMax, D76 and even caffenol, but no-one really seems to say what they're good for. Meanwhile I'm reading through "The making of 40 photographs", and Adams is saying he's developed the negs in this or that developer with normal plus one or what-not.
At the moment I've got a small shot of Tri-X, and I can get HP5+ from Boots nearby. I scanned the last lot of Tri-X back from Peak yesterday, and I thought they were rather grainy, though the negs don't look thin. (Also found a watermark, black mark Peak!) I'm not after grain particularly.
So, what would be a good buy for starters? Particularly a kit, since I'm a simple-minded soul?
(* Except I'm not really sure what "agitation" means, precisely, having seen various posts about people doing too much of it and getting odd marks near the sprocket holes...)
That's me told.
I, and many others use a V500 or one of its close relations. Results are fine not up to wet printing or a proper lab scan but more convenient and cheaper. I get better raw quality from my D3100 vs the scanner but that's not the point for me any way.
something that apart from using Polaroids (or suchlike, which is also not an option for 35mm film) is impossible with film.
Fair enough, although how prevelent they are and if film is still available for them might be an issue aside from the price of a) buying the back, b) buying the film (quite expensive for each pair of images), and the amount you would have to have to use to teach, I still think Digital is best for that and the fact that there is/was an instant film solution wouldn't change me opinion on that.Au contraire monsieur... http://www.mir.SPAM/rb/photography/hardwares/classics/nikonf4/filmbacks/index1.htm
(About half way down).
Steve.
What else would I need to do films to paper from this: http://www.ebay.co.uk/itm/191129198427?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Other than a bag???
Whoops! If anyone on here buys it I'll chuck in a film changing bag. I just forgot to list it
