how much should he ask
mercmanuk
Hi a freind of mine has a Nikon d70s
discription
The D70s not D70, the reflex body includes the AF-S DX 18-70mm lens that is ready for the most common types of shots.
SPECIFICATION
Type Type DSLR
LCD display 2" (5,0cm)
Burst Mode 3 images/sec
Timer 2 - 20 sec
Internal menus English, French, German, Spanish, Italian, Japanese, Korean, Swedish, Chinese, Dutch
Instructions included French
BOXED AND IN AS NEW CONDITION
CHARGER, 18-70MM LENS, LEAD AND SOFTWARE & MEMORY CARD
ALSO COMES WITH USUAL STRAP AND CAP ACCESORIES
how much should he bee looking at, it is as new condition
Regards Mark
Why not look on eBay and see how much they go for? When I wanted to buy a used D70, that's what I did.
Hi that a good idea, he thought someone on here my have a good guide in case someone tries to rip him off, he inherited it from his father who only used it a couple or times before he died,
Many thanks Mark.
I'm sure that the 70s was designed without the filter in front of the sensor, which allows it to take IR images, one of the few DSLRs that do this, so should be a good selling point and increase the value in some cases to the right person
Trev
Trev
No,it still has the filter, but it is less aggressive in filtering out IR than the newer cameras. You still need to use a filter for IR work with a standard D70s, however, it is one of the few Nikons that can be easily DIY converted and it also one of the few Nikons that can flash sync up to it's maximum shutter speed (1/8000 iirc), as against the normal 1/250 :D
