Getting better. @woof woof I think the medium burst setting helped tonight.
I need to get a bit closer though, but that should come with practice and better locations.
Good luck with it Keith. You seem to be able to get to grips with things pretty quickly so I'll expect some excellent BIF pictures from you tomorrow, if not later today![]()
Good advice and great shots on your Flickr link. Where do you go on Flamborough? I have been to Bempton Cliffs a few times but have yet to find the right place at Flamborough.
Thanks Derek, yes it's small steps in the right direction, but as I improve I can see that the camera will be capable of some nice shots in the future.Very well done, Keith. Great progress in such a short space of time indicates how things will turn out with lots more practice!
Yes I've been playing around with the focus options, I found the full 49 point focus was good for birds in the air.I use expandable AF point if I have time and opportunity to to choose and thumb wheel the AF spot around. If the birds are going to unpredictable in flight then I use the Zone AF, so Mid, top, bottom, left, right of screen. This guarantee I get the shot, but not eye of head focus !
Problem i have is deciding which mode to use if you are on a general walk about as you have have Robin on a bush near you, and then you may have a bird/s landing in water !Yes I've been playing around with the focus options, I found the full 49 point focus was good for birds in the air.
At least my Canon 7Dii has quick selector for changing modes, though sometimes even that is too slow !
I can relate to that, last night I was switching to static birds and kept forgetting to change the focus mode.Problem i have is deciding which mode to use if you are on a general walk about as you have have Robin on a bush near you, and then you may have a bird/s landing in water !
I must admit I haven't even played with the colour popping setting yet. This does align with some other advice I have received, keep the ISO low and lift the exposure compensation.Make sure the camera is NOT set to do colour popping... We were lucky enough to have 2 Buzzards up with both being mobbed by Crows. I even managed to get a few grab shots before realising that something wasn't quite right...
View attachment 357443View attachment 357444View attachment 357445
Fairly hefty crops but otherwise SOOC, posted to show what can happen when the ground/button interface is sub-par!!!
Lesson to take from these shots is that stopping down a little will help with sharpness - ISO-200 is the base ISO for this body and it'll cope well with up to 1600 and beyond.
Shoot a test shot (IF you have time) and add exposure compensation as needed (+1-2 stops would have given me far better detail). The tests will show up any major settings cock-ups too...
Be prepared! I wasn't really expecting to see the action so hadn't pre-checked settings etc. before grabbing the camera from the bag and grabbing the shots - PPPPPP! (Proper Planning Prevents P155 Poor Performance!)
I am leaving all that for another day at the moment, I realise that the camera will help me when I learn to give it the right instructions, but for now I am just keeping things simple and doing somethings the long way around. Funny enough I closed the screen while the camera was on the other day by accident and it changed the interface. I did a quick factory reset to get things back to how they looked previously.The quickest way to change setting when out and about could be with a custom mode. It's quite easy to do, you just set everything and then save it.
To be honest they have been blown out by the metering and low I.s.o setting .. I would suggest using 800 iso and +1 full stop of exp comp . By using exp comp you will lose shutter speed hence the higher I.s.o … it’s a formula that has worked for me with canon/Nikon/ OlympusMake sure the camera is NOT set to do colour popping... We were lucky enough to have 2 Buzzards up with both being mobbed by Crows. I even managed to get a few grab shots before realising that something wasn't quite right...
My views on this...
1) Find the right location, know the subject, and try and pre-empt what the bird will do. Watch how birds move just before they take off. That little flinch of their muscles might give the game away. Point the camera at the right spot, focus it at the right spot and don't move it. Eventually the bird will hit that same spot you're focusing on. Perhaps 99% of the time it won't work but its worth it for that 1% success rate.
2) Very fast shutter speed. 1/2000th second. You can assist yourself here by underexposing by a stop or so and then doing some work in post. This has helped me a lot with all bird photography.
3) Try not to shoot into the sky. This will probably expose for the sky and not the bird by a lot. You might be able to find a hill where you can look down on the bird. This will help you get the right exposure. I have an old hill fort near me where I can look down on Kestrels - they keep perfectly still in flight and you can look down on them. Still not easy though.
4) I've found that a small bird in flight (i.e. robin) needs a minimum of 1/4000th second, but that's without a flash. I never use a flash. Even at that speed you get wing-tip movement. But that isn't necessarily a bad thing. You're the judge.
5) Remember, when you see good shots on social media you are looking at the 1 in 10,000+ success rate. Also, a lot of good shots are of tame birds in controlled environments. Wild birds are so difficult. Don't give up!
jump by jeff cohen, on Flickr
dun flocking by jeff cohen, on Flickr
breakfast is served by jeff cohen, on FlickrAnd then you post this stuff...ROFPMSL. I would be totally ashamed to post photos as bad as that .. just stick to being a barrack room lawyer
yep loads there from 2018 heres a starter G80 + PL 100-400 handheld AND food for thought sometimes you tend to forget just how good a camera you no longer own was ??? hmm e.bay here I come
That quoted post was from 4 months ago,And then you post this stuff...
Easy on my part.On the other hand, revenge is...![]()
Really, you're comparing those images from Jeff, against the ones you posted earlier!? Sorry, but Jeff's are head and shoulders above those.You're quite right - it was naughty of me.
GSC_0924 by Gilbo B, on Flickr
HSC_8909-Edit by Gilbo B, on Flickr
HSC_9222 by Gilbo B, on Flickr
JSC_5988 by Gilbo B, on Flickr
ZSC_2145 by Gilbo B, on Flickr
AF8A5311 1 by Gilbo B, on Flickr
I've been using red dot sights for decades; but I much prefer to use the viewfinder when I can. But when the action is too fast or too close (too much lens) and I'm having trouble just getting the subject in the viewfinder, then it helps a lot (some images vs none).I'm not sure if it's already been mentioned, but a red-dot sight helps immensely.
We have a winner…. I was trying to log in via my IP…
Thanks everyone for your valuable input
Any recommendations for red dot sights that are compatible with Canon DSLRs.I've been using red dot sights for decades; but I much prefer to use the viewfinder when I can. But when the action is too fast or too close (too much lens) and I'm having trouble just getting the subject in the viewfinder, then it helps a lot (some images vs none).
A big problem with most of them is that they are very sensitive... if you touch/bump them at all they lose their alignment.
