<snip>
Dont ignore the (not so high tech) method of using a reflector - That can be used with flash, and a good one will do half the job for you
<snip>
You could consider kit like the Lencarta Safari 600 Generator, with a beauty dish and a ringflash. That will overpower the sun easily
I use a piece of cloth over the back of most DSLR's in the UK (all be it it is often my jacket) out in the field, just improvise
http://strobist.blogspot.com/2008/04/on-assignment-controlling-daylight-pt-1.html
+ the rest of the site is a pretty good resource
Tried the reflector, made a good difference, but I don't currently have anything big enough. I am looking into ordering some of them really big ones to mount wall-like.
The Lencarta Safari 600 you talk about, would it be enough for the amount of ambient light I've got here. To give you an example of the amount of light, ISO set to 200, 3-stop ND on lens at f/11, I get a shutter speed of 1/4000s. If I remove the ND filter everything is all washed out, just a while rectangle image I get.
The cloth on the back of the camera, doesn't work at all here :shrug:
Thank you for the suggestions. I think I want to go with studio lights and a generator, I really don't want to keep buying Speedlights (we're onto 5 now)!
Wail bud, I could refer you to some earlier posts
The facts of the matter are these.
The sun is very bright and you need a huge amount of studio flash power to match it, let alone beat it in the desert.
The
only way to do it is to nuke it with masses of flash power. You then have the problem of the flash x-sync shutter speed so you then have to add neutral density fliters to reduce the brightness of everything down to the x-sync max.
Things like HSS and the x-sync tricks you can play with cameras like the D70/D40 and a couple of others that have switching CCDs (almost all current cameras use CMOS) or the Hypersync feature of Pocket Wizards does nothing about the fact that the flash isn't anywhere near bright enough in the first place even if you can sync it.
The easiest way (and it's not at all easy) would be to build a bank of reflectors into a parabola and focus a pool of light on to the model. You'd have to hose her down at frequent intervals (she'll poach nicely) but at least you'd get the exposure level you want.
Can't you just wait until the sun goes down?
So, it's the bank of reflectors and pouch the poor soul
; I can just read the BBC headlines ... "Saudi photographer, on tips from TP, poach a sexy blond model in the desert of Arabia" :bang:. Will not go well with my Visa application to enter UK :razz:
On a more serious note, would you suggest I go with the studio lights and generator or spend the money of the super large reflector?
Problems with the reflectors, wind, mounting them, and as you've said, poaching the model.
I wish I had a horde of assistants following me around on every shoot.
But I don't have, they cost money, and that's something I don't have .. but it's a necessity to do this. Would have much preferred to have bought a D3x and stuck with Landscape & Nature (34 years been doing that, 34 years and now I waste my money on this project).
thats what the side of your car/jeep is for
, but the camels are down at base-camp, a good 3 minutes down a sandy dune and another 10 ~ 15 minutes to get back up. I'm too much of an old fart to keep doing that :thumbsdown:
