I don’t think this is an exhaustive list, NHS tends to be conservative (I knowI know grapefruit shouldn't be eaten if you're diabetic, not heard about it for anything else
Really? I’m guessing you’ve taken medical advice as generally it is not advised to drink grapefruit juice whilst taking some medications. I too am on Amlodipine and was told not to.
I also recommend the free app IBP for iPhone & iPad (maybe Android too?) which I’ve used for years to record blood pressures and has never failed. Does means, graphs etc.
To be honest, I’ve used for so long I can’t remember if I paid. It was originally but Withings the French BP etc machine supplier. It will feed data into both Apple Health & Withings Health app (and thence into GPs AirMid & SystemOnline apps).You can export from iPhone & iPad both directions and/or export snapshot photos or Excel etc, has all worked flawlessly for me.Thanks for the heads up about the app. I went for the paid version, all of 89p.
Yes some of them do and some will calculate a mean of 3 readings and send that to your phone — because (see above) my BP swings about so much I prefer to have all the data pointsDo none of the Omrons record or do they not do a smart version. Main reason I went for the Withings was for the app, better to go off a trend than individual results.
Yeah my Withings one has a mode for taking 3 readings X amount of time apart then averaging them.Yes some of them do and some will calculate a mean of 3 readings and send that to your phone — because (see above) my BP swings about so much I prefer to have all the data points.
i let my first year students practice on me with a "proper" sphygmomanometer so some days i get my B/P taken 20 times..even though i hate it
depends if were doing catheterisationMake them practice on each other? Or is that not allowed any more?
Just curios, how do they check it?When I go for my annual check I take our Omron M2 and the nurse checks it against her monitor which is checked frequently, maybe daily. Some years ago my doctor asked me to bring it in to calibrate it so they're quite happy to do that.
I surmise, parallel checking i.e. take a measurement on both devices......in principle if the patient owned one is within acceptable variance of the clinic one it would be deemed to be 'accurate'. But unless the surgery have a technical section I suspect the patient's device cannot be calibrated. NB though how the surgery ensure their own units stay within spec, I would hope they are sent on rotation to a qualified technician!Just curios, how do they check it?
“Checked quite frequently“ is interesting. The manufacturers of the majority of modern automated NIBP monitors state either no servicing is required or that it should be at intervals of ~2 years. Not exactly what I would call frequent.When I go for my annual check I take our Omron M2 and the nurse checks it against her monitor which is checked frequently, maybe daily. Some years ago my doctor asked me to bring it in to calibrate it so they're quite happy to do that.
Yes, Omron say 2 years and add “Please consult your local OMRON representative.”, good luck with that, maybe they have them in Japan“Checked quite frequently“ is interesting. The manufacturers of the majority of modern automated NIBP monitors state either no servicing is required or that it should be at intervals of ~2 years. Not exactly what I would call frequent.
I would hope they are sent on rotation to a qualified technician!I surmise, parallel checking i.e. take a measurement on both devices......in principle if the patient owned one is within acceptable variance of the clinic one it would be deemed to be 'accurate'. But unless the surgery have a technical section I suspect the patient's device cannot be calibrated. NB though how the surgery ensure their own units stay within spec, I would hope they are sent on rotation to a qualified technician!
I’ve done a bit of ‘research’ (ie googling) and I suspect BPMs.are never recalibrated! Mostly they just recommend “checking” against the doctor’s machine which is not calibration!I surmise, parallel checking i.e. take a measurement on both devices......in principle if the patient owned one is within acceptable variance of the clinic one it would be deemed to be 'accurate'. But unless the surgery have a technical section I suspect the patient's device cannot be calibrated. NB though how the surgery ensure their own units stay within spec, I would hope they are sent on rotation to a qualified technician!
All of the low cost units are checked against a known good reference. In event of a failure they are disposed of and replacement recommended. The check, certainly on Omron units, is most often a static pressure check and a number of points across the measurement range.I’ve done a bit of ‘research’ (ie googling) and I suspect BPMs.are never recalibrated! Mostly they just recommend “checking” against the doctor’s machine which is not calibration!
There are several firms that offer calibration (cost around the same as a new cheap machine) and are evidently aimed at doctors but none I’ve found say how they do it so I suspect (having a suspicious mind) they just check they are working, wait a few days, and send them back with a bill.
I’ve done the sameWhen I go for my annual check I take our Omron M2 and the nurse checks it against her monitor which is checked frequently, maybe daily. Some years ago my doctor asked me to bring it in to calibrate it so they're quite happy to do that.
I’ve been heavily involved with the routine maintenance and repair of medical devices for close to 30 years. Calling Omron “good” is a bit of a stretch.My wife was a cardiac nurse specialist up till a couple of years back so she’s well aware of what’s a good machine and what isn’t. We’ve got an Omron.
As I said earlier, I’ve got 3 of the basic ones. They all have the same annoying fault that, like most cameras, there’s no informative indication of the battery state. There’s no actual battery check and they seem to give a “Half full”indication with batteries that test as near new voltage. I guess the answer is to use an external power supply which is fairly inconvenientI’ve been heavily involved with the routine maintenance and repair of medical devices for close to 30 years. Calling Omron “good” is a bit of a stretch.
As with everything at the lower price points a number of design decisions have been made to meet their build costs. Omron are one of the few brands where those compromises are acceptable.
that's the beauty of a manual monitor - no batteries required - it's almost like shooting an old fm2As I said earlier, I’ve got 3 of the basic ones. They all have the same annoying fault that, like most cameras, there’s no informative indication of the battery state. There’s no actual battery check and they seem to give a “Half full”indication with batteries that test as near new voltage. I guess the answer is to use an external power supply which is fairly inconvenient.
Since the discontinuation of mercury sphygmomanometers, many years ago, aneroid ones have taken over. However, to comply with MHRA guidelines, they come with a heavier maintenance burden as they should be checked for accuracy every 6 months. That means they will be checked four times more than automatic, electronic, units.that's the beauty of a manual monitor - no batteries required - it's almost like shooting an old fm2
I’d suggest taking two readings each time, and ignore the first.Only been taking mine about a month now and noticed it can vary a little day to day.
High 137/86
Low 128/68
It's it best to just take a couple of readings a week each one in itself an average of 3. Then using the monthly average to show health?
It's automatic it does either 1 or 3(30, 60, 90 and 120s apart)I’d suggest taking two readings each time, and ignore the first.
The time of day is also going to make a difference, especially if before or after food. So take them at the same time each day or take several across the day.
The surgery are using a method I have not heard of in 30 years within the NHS. I would guess they are using some go / no go criteria which can only take a single value.When I take my own I do 2 readings and use the second.
When the surgery asked me to take readings to determine an average, it was for a week and they said morning before breakfast, middle of the day & in the evening before going to bed.
Hmmmm? For clarity I was not evaluating the average, I provided the surgery a table of my weeks readings.The surgery are using a method I have not heard of in 30 years within the NHS. I would guess they are using some go / no go criteria which can only take a single value.
Thanks I misunderstood the earlier description.Hmmmm? For clarity I was not evaluating the average, I provided the surgery a table of my weeks readings.
The HCA taking the reading when I went in for my reading was not happy about the three off tries she took (I was a tad late getting...so perhaps a bit stressed) so she asked if I had my own device. That is when she asked to do the measurements I described.
I guess I’m an outlier here. I never had any particular instructions from the GP. I’ve been taking them when convenient or I think of it! I have the impression (without studying it) that the first reading tends to be high. I alway take 3 readings and try for 5 mins apart. I record them all in the IBP app and rely on it graphs for the mean BP. It also gives bar charts for max min & mean. And you can choose day/week/month/3m/6m/year and am/pm/both. One can add notes and record pulse & weight.I’d suggest taking two readings each time, and ignore the first.
