Help with distortion
mattyg
Matt
Hiya Folks
Can anyone give me some tips on how to remove the distortion on this shot. I hadn't noticed the Legs of the Pier until someone pointed them out.
Southwold pier night
by mpg Photo's, on Flickr
I have LR5 and PS CC
Matt
filter > distort > lens correction
then as below - click for bigger
I level to a central point, and then vertical perspective trasnsform
change the edge scale, and then you can decide whether to clone in the missing corners, or crop them out
This was CS2 - but I presume the CC has similar, LR5 probbaly does too
LR5 has a function within the develop module that will cure this. Various options including fully auto which I have found works 90% of the time
Thanks folks. I has missed that adj. I think I had tried everything else but that one.
Cheers. I'll post up the finished shot later......When its finished'ish
Also.... ensuring your camera is parallel with the ground will reduce distortions.
