archangel
- Mike
- No
I was going to do my slow cooked lamb until I saw your thread and you saved me at least a tenner - guess I ought to share my secret recipe...
Simply take one Lamb shoulder and insert sprigs of rosemary under the skin, then rub with oil and season then roast in a hot oven (220-ish) for about 15 - 30 minutes then turn down the heat to about 150 - 170 and continue to roast for about an hour.
Then add around a pint of stock and some white wine, enough potatoes to feed the family and as many unpeeled garlic cloves as you like then cover with foil and roast again for 3-4 hours until the meat is utterly tender - this can take longer and as the meat can take it I always allow 4-5 hours but it depends on how big your joint is.
It is worth checking the amount of liquid and topping up as needed, and I like to remove the foil and turn the heat back up for the last 30 mins to crisp up the spuds a little on the top - they will absorb a fair amount of the liquid so will be soft inside, as will the cloves of garlic which need to be squeezed out and savoured...
The house smells wonderful while this is cooking so try to go out for a drink for the last hour as the temptation to serve it early is hard to resist.
Got my pork marinading now - enjoy yours Ruth !
I HATE LAMB.....just saying
