just_dave
- David
Hi,
I currently have a Sony Vaio VGN-NR32L (which I have had for nearly 2 years with no probs, running Vista) and was just using it online with no problems and also trying to update/unlock my iphone at the same time. itunes froze so I restarted the comnputer and since then my sound not longer works (just says no audio device installed), my wireless internet no longer works (even down to the green light on the switch not working if I diagnose and repair it pops up with "there might be a problem with networ adaptors" "the network adapter marvell yukon 88e0839 is expecting driver or hardware related issues and says the same for LAN Express ASIEEE 802.11g PCI adapter" also if I have the battery plugged in it is telling me that the battery may not be support and to put into hibernate mode and remove and re install battery (works fine with battery remove and mains poower only. And also none of the usb connections seem to be working/.
Please could someone advise me on what is the best thing to do with this or at least point me in the right direction of what to do to resolve this issue?
Or is this the perfect chance for me to convince the Mrs that its time to get a new laptop (or even a MAC?)
Many Thanks in advance
Dave
Dave
