Check the electrical contacts on the lens/camera are clean and not damaged.
They can be easily damaged when changing lenses if one is a little too heavy handed!
Is the problem just with the one lens? ....if so then the box is ok and the problem lies with the lens, by contrast if the problem is the same with all your lenses then it would seem that the box is at fault!
