Excuse if I'm out of order - If you are a pro ' you will know about this - have you tried putting body into manual mode and setting the lens' hyperfocal distance , so that the camera is in focus ( even if thru the viewfinder it doesn'took as if it is) from a predetermined distance to infinity? That way all you hVe to do as the animal runs towards you is to be aware of the minimum focussing distance available on that setting ( I.e., wherever the infinity symbol is read off the number in metres opposite it.
Yes, I remember
But I think it's important to be clear on this. Yes, IS/VR takes maybe half a second or so to get up and running, but that should already be well underway with half-pressure on the shutter release (or AF back-button activated) in which case IS/VR can only make things better.
A good thread on servo-tracking dogs here http://www.talkphotography.co.uk/threads/help-with-dog-running-pic.461016/#post-5329736 including Tim Dodd's excellent advice, though it looks like some of his pics are missing now.
IMHO, the OP's problem centres around AF set-up and shooting technique. It must be really, because with an easier subject - say a car travelling slowly towards the camera, or maybe a cyclist where it's easy to keep the AF point accurately nailed - I'd confidently expect 80-90% hit rate from his camera/lens combo. But you must keep that AF point accurately pinned.
PS I always try to use a monopod for this kind of work (IS/VR on) - it really keeps the camera end of things steady, and that's half the battle.
good grief a monopod? with a dog running round you... by the time you move camera and monodpod to a different position the dogs gone
IS/VR..half a second... a dog running at speed and you half press.. have you any idea where the dog is and your focus is half a second later ?
All I can say for sure is.. IS/VR is a problem DEPENDING ON YOUR TECHNIQUE which is what I originally wrote.. if you can lock and track then shoot at leisure it should work as you describe.. however if you point lock and shoot all at once then your in trouble.. I dont know the ops technique hence why i advised turning it off.. not permamnant but just to see if it helped...... my technique is the latter and IS/VR is a problem.. after taking your adivive I do now use IS for sport in certain condition where i can use pre emptive focusing
i still say he should give it a try... its not going to kill him to try.. am suprised your so against it....
