help canon 400d
flyer
Help ...
just took delivery off a 400D
It will not work...
The shutter works without the lens ..but when the lens is on it wont...
please tell me its something simple and that i dont have to send it back..
totally pi---d off ...
HELP..
what lens?
oh and make sure the battery is charged
and what happens when you try to take a pic?
ERR code?
all the lights go out?
what?
battery is full ..the lens is the standard canon zoom 18-55mm
cheers
have you taken the lens cap off?
ERR code?
what?
does it autofocus?
thanks for taking the time MMCP42
I have just removed the lens and flicked up the little glass plate inside the body.
it must have been stuck
it is now working..
is this common..
cheers
gulp
hope you didn't touch the front surface :nono:
the mirror is silver surfaced - be v v careful
it's not common - not unheard of though
all working now?
odd that it worked when the lens was off, but not with it on
you did turn the camera off when you put the lens on?:rules:
no i lifted it from the bottom ..the frame of it..
well its time to start learning what all these switches and buttons do..
thats if i can get it off the wife..
I / we are new to this, so you will probably get bored of answering, what will probably be very simple questions ..
but i am looking forward to learning and hopefully taking some very nice pics..
cheers again.
would you have any idea where i can get the software package for the same 400d..
it was an ex display model and didnt come with the discs..
should have come with discs though!
welcome to the forums!! dont be afraid of asking such questions...we were all new to it once :)
RAW is a file format, just like JPEG, only RAW is data.
JPEG's are essentially the end product of RAW's as the camera gets the data and creates an image from it. But you can take your shots in RAW which means its easier to process on your computer as rather than changing pixels that are set like stone, you are changing data which is just like a load of numbers. Therefore making RAW more flexible but a much larger file format
