Box Brownie
- No
Crumbs what slow film @ ASA (ISO) 10, 32, 64 there was during that period (the slowest I recall was Kodachrome 25) Is there film of any type still made with that low an ASA ???
The thread might get even better help in the film section.What a brilliant thread guys, its good to see such helpful replies, especially to a new member![]()
It's edge of the seat stuff and I know nothing about the cameraWhat a brilliant thread guys, its good to see such helpful replies, especially to a new member![]()
The slowness of the films the camera's designed to take could be a slight problem BUT it's easy to overcome with neutral density filters (ND). Once it's known what speed the thing's set at, just use the NDs to "adjust" the apparent sensitivity.
Ha - if you had any. And some sellotape to attach them with?BUT it's easy to overcome with neutral density filters
Hey! We're hardly in the realm of through-the-lens metering here. Slow down a bit.won't an ND filter just make the cameras meter compensate
I don’t but I should as I swapped my then Diax for a Paxette with a telephoto lens in 1957 so right vintage. All the films were badly scratched, might have been sand (Aden) or the local processing but I got rid of it p/x for an Exa 1It's edge of the seat stuff and I know nothing about the cameraI'm just hoping the OP can get some good use out of the camera
Hope you get it sorted Samantha.
Agree, and really the OP would be better off with an entirely manual camera of the same vintage I think.On the ISO/ASA front, it's OK to pull films as well as push so a ISO 100 could be shot at 64 and the lab notified to process accordingly.
I'd be more concerned that a light meter of that age is unlikely to be accurate and if the camera is fully auto then it is going to be hard to get any decent shots.
You could put the ND filter over the meterHa - if you had any. And some sellotape to attach them with?
