Grey blob in vision
DorsetDude
Spud
Keith
i'll be minding my own business watching telly when suddenly something wont look right. I then look at a plain surface and theres a big grey blob/smear in my left eye's vision. Over a few minutes this gradually reduces in size and then I can see again normally. Much "larger" than the floater type things.
What the heck is it and should I be worried?
Could be a form of migraine ... as with all medical concerns get it checked out by Dr/Optometrist :)
  • Like
Reactions: Nod
I've got a thing called "central serous retinopathy" in my right eye, when I first noticed it there was a dark hard edged balloon shaped area in my vision when I looked at a light coloured surface, I went to the optician and they said there was a swelling behind the retina and sent me to the eye hospital for diagnosis, nothing to worry about and should put itself right in 3 to 4 months, that was 3 years ago, it has faded somewhat but can vary in intensity, just a slight bleed behind the retina that causes a bulge and a dark shadow, doesn't trouble me now I know what it is, I have to use my left eye with my camera, you should have it looked at though in case it's something different.
More info,http://en.wikipedia.org/wiki/Central_serous_retinopathy
Less pornography. ;)
Your Mum told you you'd go blind if you didn't stop that..........
seriously though, see the doctor.
Might be eye related or brain related. If eye, optometrist might be more helpful. If brain, go see your doctor.
Yep, they are called aura migraines, I get them, only really a problem if I am driving, I have to stop because I can't see a darned thing ahead of me.
As everyone has said, pop to your optician to get eyes checked, then if clear, it's the doctors. Either way, you are worried enough to be asking here so that should be indicator enough to get it checked out by professionals.
Sounds like a silent migraine. My optician says they are nothing to do with your eyes (which is a bit weird).
Had new bifocals for evening wear couple of weeks ago wonder if its them triggering it? Maybe. It does feel "Migrainey" but without the ensuing headache and usually my migraine pre-cursors are like zig zag transparent flashes round the edge.
Oh yeah. Google says it could also be a stroke. So, you know, doctor.....
I would go and see your optician as soon as possible. It might be nothing but it could he start of something which could permanently affect your sight.
Al
its the missus leaning over him to see if he's still alive ;)
I get those too... starts in central vision and then gradually moves outwards until it "falls off the edge" of my vision.
Kinda trippy!
Seriously. See your Dr. If you need a referral, they're the best one's to tell you to whom.
Kinda trippy!
thats exactly the aura migraine thing, mine moves across my vision, starting on the edge and drifting across the middle to the opposite edge before falling off altogether, lasts about 30-40 mins in all. Like you say, kinda trippy ;)
Eye test soon as possible, mentioned it to my daughter who is an optometrist. Could be a number of things some more serious than others.
Dr likely to have quick look and say to get eyes tested asap
Try not using the new specs for a while and see if the blob stops.
TBH though, I would go to the optician as a start then the vet just to get reassured.
Just keep your hands on the veg (or is that what's causing the problem?) and make sure he doesn't put you down as a hopeless case! (Or she, of course!!!)
He's a bloke though.
Probably be a month before he even looks for the Drs number ;)
I think I need the Drs (digital rehabilitation service number). I keep seeing every thing as small squares.
Get it checked out by an optometrist. It sounds to me like it could be some sort of defect with the retina. Maybe a fluid sac or a tumour behind it. If left untreated you could lose your sight in the eye.
Of course it might not be anything that dramatic. I'm sure there are loads of conditions which I've never heard of which could be causing your symptoms. But as far as your eyes are concerned, it's never worth taking any risks, so always think about the worst case.
I've had a tumour in my left eye since about 2010. It's called a choroidal haemangioma and it's basically a sort of benign fluid tumour which causes the retina to bulge. The symptoms are varied and include dark shapes in the centre of the field of vision, greatly reduced contrast perception, reduced colour perception, and distorted vision. Just before I went in for treatment on it this summer, I made this mockup to try to illustrate what it does to my vision. The left half of the image represents how I see with my left eye, and the right half represents how I see with my (normal) right eye.
(Obviously that's not how things appear day to day. My right eye effectively takes over, so what I see over the whole field of view is quite good. But if I close my right eye, what I see is quite bad.)
The good news is that it's treatable. I had laser treatment in June after my eyesight in the left eye had deteriorated quite markedly (from 6/18 to 6/60). It's called photodynamic therapy and it targets tumour cells by infusing them with some sort of photosensitive chemical and then zapping them with the laser. It seems to have had a positive impact. I'm currently waiting for the 6-month review and I don't have any numbers yet, but most of the symptoms are significantly reduced. I might need a second burst with the laser next year, but it's really not invasive at all. If I hadn't had the treatment I dread to think how far the eye might have deteriorated, give how rapidly it was going downhill at the time.
Get it checked out.
Internet diagnosis is no diagnosis. If you cannot get fast access for a professional examination then why not ring the NHS for advice.
Dust spots.Get yer pupils cleaned! :D
http://www.nhs.uk/Conditions/Uveitis/Pages/Introduction.aspx I had this many years ago......sounds similar but def get it checked out
i suffer from re-occurring uveitis as well usually when i go abroad ,so its either the dry heat abroad or the pressure in a plane kicking it off ,the last time was really bad because as well as the normal 6 week course of steroids i had to have an injection directly into the eyeball ,not exactly pleasant
I feel your pain......First time i took it I was rushed to hospital after mis diagnosis by a boots optician......told that I could lose my vision in the eye if not treated straight away..thankfully I got there in time......and like you say not pleasant.....never felt pain like it.... My grandfather had it also and he lost the sight in one eye
