Dr_O
- Dr Ozone
Hi
Was set to get the Calumet Heavy Duty stand but am questioning if I really need to spend twice as much as say a lencarta or another make?
I was thinking it would avoid any sagging issues if Vinyl was used but after reading a bit more I'd probably stick to paper/ muslin anyway as it seems 'good' vinyl or vinyl suitable for photography is hard to find at reasonable cost.
So would I be wasting money by going for the heavy duty one- are there other makes I should consider that are just as sturdy?
Also, looked at perspex for the floor to place on top to stop holes appearing when on carpet- 2mm or 4mm or are a couple of small (portable) sheets of ply or other material for underneath a better solution? It would stop reflections if that look was not required I guess.
Any advice thanks-hopefully I've made some sense
