Gimp + UFRaw = HUGE jpegs
ecniv
So I guess I have a setting wrong somewhere.
I'd expect the jpegs (after image flatten) to be around 4-6mb. They are coming out around 16-20mb. Apparently at 72ppi... I'd expect that huge file size from 300 ppi...
Current work flow:
Open Gimp
Open Nef file (uses UFRaw plugin)
Tweak as required
Click Save to send to Gimp
In Gimp I usually duplicate the layer, add an unsharp mask (default) and change to either Screen or Overlay 60%.
Save as Gimp
Image Flatten
Save as Jpeg - 100% & best quality.
Since the only thing that has changed is that I've used UFRaw, is there a setting I should be using in Gimp?
I checked the recent images and they state file type : raw data file at the bottom. Even on the jpeg.
Is this the problem? and how to fix it?
Thanks in advance
haha - thanks! :)
doubt there are that many using this combo.
Had to change quality to 97% to shrink jpeg. Only works on some, others still at 16mb. Only way I can get them to shrink is using the second setting on the compression (usually left at best quality).
thanks for the bump.
Hoping there is an answer as when I process through capture nx it doesn't do this. Same through Elements. But I like the in Gimp flow :)
