Fujifilm X-t1 firmware
c22w1
Chris
Hi
I have just bought a second hand Fuji XT1 for a very affordable price due to the rear screen not working, the EVF works perfectly. I don't tend to use the screen much so it's no great loss to me.
I have been trying to find out what firmware it is on but to do this it says to hold down the DISP button while turning on, trouble is the viewfinder remains blank when I do this, is there a way to check the firmware and also uprate the firmware any other way please (updating the firmware is done the same way so I won't be able to view anything)?
Thank you
Tried it in all options but the EVF remains blank (only while checking for firmware ie when holding down the DISP button while turning on) at all other times the EVF works perfectly.
Look in the EVF as it powers up, does it show there, if not toggle the View Mode (button on side of EVF turret, to make sure rear screen is on, the try the method you've been using up to now
why not just upgrade to latest version anyway?
go to the Fuji website and see if the upgrades from new were worth you having, if not then maybe don't worry about it.
Might it be worth getting the thing repaired?
Ring and ask. Nothing ventured nothing gained!
You will need your screen to format your discs.
OK, good that you have that sorted out.
Some cameras put the firmware in the EXIF (possibly the MakerNote) though it doesn’t seem to be shown in all EXIF readers. Hard to see why it wouldn’t be included in all image files :(.
When I import my Fuji xt3 files into capture one, it lets me know if there is a new firmware update and which version the camera is on. Not sure if this applies to Fuji xt1?
I think that proves it’s in there somewhere. You would think the manufacturer would want it in the files for test purposes and so on.
