Fujifilm s100fs questions - 2
355858
Ben
1. does anyone know why the B (bulb setting on my s100fs) only lasts around 30 seconds then cuts off? is this standard? as you hear of some cameras leaving the shutter open for minutes?
2. Does anyone know of a 67mm ring flash unit to fit the s100fs?
thanks Ben
anyone?
I can't answer, but you may have more success with an answer in the Fujifilm forums @ DPReview here.
There may be one or two more owners of your camera there. ;)
Good luck. :)
Good luck. :)
Thanks for that info as I am looking at buying a Fuji camera soon :thumbs:
As for the bulb setting problem it will probably be set to that as I know the Fuji S8000fd has something like a 4 sec bulb which is a bit limitation if you plan night time shots
