freesat help...
We've got Freesat running through an unused sky dish that was up when we moved in. If you want to run them side by side then another LNB with the cable running to the Freesat box will work perfectly. The HD channels are quite good with Freesat and they're adding more all the time. Well worth using IMO, our TV has freeview built in too but we hardly ever use freeview on it as Fresat has everything we need.
