Fractalius & CS5?
JDP
James
Hi guys,
Has anyone managed to get Fractalius working on CS5? it worked okay on CS4.
I install it into the photoshop plug-in directory but i am unable to find the addon in the dropdown in photoshop. Does anyone else have this issue?
I'm using Photshop CS5, Windows 7 64bit.
Thanks.
JDP
Yep works fine on Win 7 64bit with CS5
Are you running the PS CS5 in 32-bit mode, though? A 64-bit OS is rather less relevant.
http://www.redfieldplugins.com/faq.htm
redifield FAQ said:
Do your filters work with Adobe Photoshop CS4 64-Bit?
Our filters are 32-bit software. Photoshop CS4 64-bit is not able to run 32-bit plug-ins. It can only run 64-bit plug-ins. Our plug-ins need to be executed in the 32-bit version of Photoshop CS4 (:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Photoshop.exe)
64-bit versions of our filters will be issued this year.
To the OP, update to the latest version if you haven't already. Run PSCS5 in 32-bit mode. See what happens.
Thank you for reminding me what it was called - I knew I had backed it up when I reformatted my computer but could not find it as could not remember what it was :)
Mine works on CS5, Vista, 32 bit
No problem. Its a great plug-in. One of my favorites. Cool, i tried to run photoshop under Vista compatibility, but i had no luck.
Oh cool, thanks i guess i have something wrong, im going to do a reinstall.
Thanks for this. I didn't install the 32-bit version, but how do i run it in that? I had a look in properties and i couldn't find anything. Im going to do a reinstall of PSCS5 along with a update, see what happens. And im going to install the 32-Bit one also.
Thanks all for the help!
No I am running 64bit OS AND 64bit CS5
Then I am slightly surprised, unless the manufacturers' FAQ is out of date and they have actually released the new, 64-bit version of the plugin.
