EdBray
- Edward Bray
I have just finished developing my first set of four 4x5 negatives in my Paterson Orbital tray (without base) stood in 1.5 litres of tempered water in a 12x16 dish @ 22° C which was on a dishwarmer using Caffenol C-L developer semi-stand @ 21° C. This took 400mls of chemicals to cover the film.
I followed my normal processing/agitation regime of 5 mins pre-wet, 30secs constant agitation followed by 3 gentle tips of the Orbital tray at 2, 4, 8, 18 minutes with the Caffenol CL drained after a further 40 minutes, I then used the tempered water in the dish (300mls a time) to wash the caffenol away with constant agitation now using the orbital's base. A further 4 minutes of Alkali Fix (2x clearing time +1) before washing with 6 trays of 400mls agitated for 1 minute and left to stand for 2 minutes each before draining, a further 400mls with a couple of drops of photoflo for a couple of minutes completed the processing.
3 of the negatives were excellent (the 4th turned out to be Velvia 50) and there was also very little mess which was nice. There is no streaking anywhere on the negatives (common sympton apparently experienced by users of the Orbital) but this may well be down to the long developing time. Much easier to load than other options I have (Taco style or Yankee tank) and only takes 400mls of developer and 200mls of Fix (constant agitation).
Previously I have always had a least one negative that has had a blemish caused by the processing procedure. I am just hoping that the suspected Velvia sheet was not the one that would have had issues.
