RichieRich
- No
If you had to buy a single filter for a wide angle lens (Tokina 11-16mm in this case), which would you go for. I was thinking of a simple UV filter rather than a polarizer due to the effect of vignetting.
I see lenses over here (Japan) just listed as being `Protective`, while others are `UV`...are these likely to be the same thing.
I only want to buy one at the moment as the pound is no longer worth the paper it is printed on compared to the Yen.
Thanks in advance.
Thanks in advance.
