For me it's a simple matter, why spend approx £1000 on a prosumer camera and then cripple it with entry level lenses?
Viper,
I shot motorsports to a pretty high level.
If you're serious about taking it further then you have to seriously consider f2.8 glass.
2 major reasons why.........
Your biggest issue with motorsport action (regardless of if you're accredited behind the armco or public behind the fences) is the unavoidable clutter you get in the background at race circuits. This ranges from fences, tannoy poles, brightly clothed marshalls, ambulances, bright air catch fences, sponsor hoardings, grandstands etc etc.
Motorsport photography is primarily about capturing the moment when action gets exciting and relating that to your viewer, NOT about showing people that the ambulance in the background that you've inadvertantly caught in the frame is an LDV or a VW and has two occupants.
F2.8 apertures enable you to use Depth of Field to your advantage and completely blur out the annoying background clutter to a nice degree, leaving all the emphasis in your shot on the subject which is where it should be (unless you're intending to show the wide angle environment that the competitors are operating within).
The example below shows a little about what I mean.
The yellow in the right-hand background is a builder's hoarding attached to a half-built house with scaffold poles standing vertically. Normally I would want to avoid this type of cr@p from my shots but unfortunately the wheel-up action happens in the same spot all the time at Oulton's Druids and to move to a spot where that clutter wasn't in the background would mean I wouldn't get the shot...."period".
I know this but you don't because the very shallow depth of field used has obscurred the clutter to a degree where it doesn't detract from the main action. That's f2.8 working for you in a way that F4, F5.6 etc wouldn't.
2nd reason is that the smaller the f-number, the more light you're getting into your camera and more light means you can achieve a higher range of shutter speeds, essential for most motorsport eventualities.
Personally with a 70-300mm lens you don't need a monopod. Save your money. The smaller lenses are not what you'd call hefty - leave that for when you get your 300mm or 400mm f2.8 prime, then you need a monopod!!!!
F2.8 is the way to go, but it's more expensive for a good reason. "No pain, no gain" and "You get what you pay for" at work once again I'm afraid.
If you're not that bothered about the quality of the motorsport shots you produce (which I doubt is the case) then you don't need f2.8 and can save your money. If you are serious, I would save for a f2.8 lens that meets your needs and disregard stuff that you don't really need.
Good luck,
Guy
but with only D300 moneyI know this but you don't because the very shallow depth of field used has obscurred the clutter to a degree where it doesn't detract from the main action. That's f2.8 working for you in a way that F4, F5.6 etc wouldn't.
I don't doubt your work Guy, and that is a nice shot. But you have been gotCould you please explain where f2.8 comes into this when you took the shot at f5.3?
I know that, but he said he didn't like the results (of Bokeh I think) from slower lenses...yet he is using the equivalent of a slower lens in f stop terms to demonstrate that point![]()
I think you'd be better with a fixed lens like the 300 f2.8 (if funds don't allow, the 300mm f4 to start with), and then another lens for walking round the paddock. Since the action in motorsport is mostly predictable, you don't need a zoom for most shots.I'd not go for a fixed 300 though as I'd rather have the zoom abilities around the paddock. Thanks for all your help.
I've been trying to get my back ground to blur, like this photo. My question, is the f number of the zoom that helps?
Any advice welcome, any apologies for the rather basic question
Just reread - so lower number better for blurring?
No, the f stop you see in the exif is the actual f stop that was set, irrelevant of the extender, so the same f stop could have been set with a slower lens, giving the same effect (albeit less sharp, due to different quality glass).But had that lens been an f4 etc, then the f stop would be higher still using the extender resulting in more of the background in focus
I'll see if I have any Nikkor AF-S 400mm f2.8 shots versus Nikkor AF-S 300mm f4 taken from the same location to confirm my point better.
Like I mentioned, that shot was just plucked from one of many. I knew it was taken with the f2.8 but as I don't use exif data I omitted to see I had the 1.4x on thus increasing the aperture.
Gc
Yeah I know, no problem with that.Like I mentioned, that shot was just plucked from one of many.
The 1.4x doesn't increase the aperture shown if the exif data (see examples below), which suggests you must have set that aperture.I knew it was taken with the f2.8 but as I don't use exif data I omitted to see I had the 1.4x on thus increasing the aperture.
Yes, you can still pick the lowest aperture, but less light comes into the camera (which the meter recognises immediately).so would the camera with the extender attached let you pick f2.8???
Also, was it definitely shot with the f2.8? Maybe your exif data is up the spout, as it says the max aperture of your lens is f4 (and I realise you may not even own such a lens). Have you owned (rented, borrowed) a long zoom?
Good head is always worth paying for... sorry.
Maybe the exif data is reported in a different way to the D70 and D700.Max aperture of the lens at f4 is probably right (i.e. f2.8 plus 1.4x converter = lost stops from f2.8).
So this is either a difference between Nikon bodies, or the TC used. I've used the kenko 1.4 - which TCs have you used?To argue your later response to fletch that putting a converter on doesn't affect your camera controls in terms of aperture....It Does, at least on my D2H anyway e.g. If I put a 1.4x or a 2x on my 400mm f2.8 I can never select f2.8 on the camera in any of the camera modes (Shutter, aperture or manual). It always compensates for the lost stop/s as a result of adding a converter to the lens.
Yes, the exif says it was shutter priority.I wouldn't have set that aperture purposely......It's too ambiguous (i.e. in no-mans land in terms of the range I use in motorsports). With shots like that I go as low as I can in terms of aperture, unless I've shot in Shutter priority and the camera has dictated the aperture setting for me.
Yes, The smaller the number the greater the blur in the background ie less depth of field or less in focus (other than the subject) and a wide aperture.
The opposite to this is a high f number which has subject and background in focus or greater depth of field and a small aperture.
I can't see how the 70/300 can be called a 'budget' lens.
In my opinion there's a lot of guff talked about DOF and aperture.
Lens focal length and distance to subject have a far greater effect on DOF than aperture. Aperture is only the third part of the equation.
Ah, that explains it, thanks.Kenko TCs dont report their presence to the body properly. The camera still thinks it has a f2.8 lens on it.
No it doesn't. Having the TC on reduces the light that gets to the meter, so even if the camera thinks it's still shooting at f2.8, it doesn't matter, because the camera also thinks it's darker.I think it means that the shots will come out under-exposed by one stop too?
If you want to compose your subject a certain way (eg, head and shoulders portrait), you can't adjust the DOF with focal length or distance to subject - ie, if you use a longer focal length, you have to move further away to keep the same composition, so they cancel each other out. So aperture is the only thing you can use to change your DOF.In my opinion there's a lot of guff talked about DOF and aperture.
