expansion scews for interfit wall mount
rgrebby
Richard
im trying to put the wall mount up and its given expansion screws but I have no idea how they work?
The instructions say nothing
The trick is to get the hole in the wall exactly the right diameter and length for the expansion fixing. The fixing is tapped into the wall leaving the threaded end (and washer and nut) sticking out.
Assuming you've made the hole the correct size, the sleeve will expand as you tighten the nut (with a socket spanner). Once the fixing is really tight in the wall, back off the nut and take it off the thread. Fit the mounting bracket over the thread, replace the nut and retighten with a socket.
Diagrams at bottom of this page illustrate it http://www.rawlplug.co.uk/index.php?option=com_content&task=view&id=7&Itemid=25
Thanks guys, I took a quick trip to B&Q and it turns out those ones were not for hollow walls, managed to pick up a few decent stronger looking ones and I now have a 2.72m paper roll up. :D
The new studio / office is coming along nicely!
Hmmm, hollow walls eh, well personally if they are standard plasterboard walls there isn't a single hollow wall fixing sold in B&Q that I'd trust longterm to support a triple 'expan' type system and I'd certainly be very cautious using more than one roll of paper - but then again I'm a belt and braces kind of guy and anything I fix to the wall is tested by it having to support my weight and I'm a big f#t b##ger.
Paul
its up now and seems very sturdy. used two 10mm bolts in each side so Im hoping it will be enough with three on there. So far just have the one but I will keep an eye on it.
I'm with Paul on this one. I'd find the stud work and fix a length of timber to that.
This will give a sturdy anchor to screw the supports to.
