John Young
- John
ExifCleaner 1.7 - FREE for a limited period
HERE
Not tried it myself - blurb below
HERE
This is a Windows application for massive erasing photographic data out of pictures. Currently ExifCleaner supports only JPEG images, and can remove photo metadata of the following formats: geolocation/GPS tags, Extensible Metadata Platform (Adobes XMP), Exchangeable Image File Format (EXIF), International Color Consortiums Profile (ICC), photo metadata of International Press Telecommunications Council (IPTC), JPEG File Interchange Format (JFIF), JPEG comments, and FlashPix.
Erasing of the metadata helps in several cases:
If you are concerned about privacy, delete sensitive info such as GPS data and date+time of taking a snap, from pictures being posted on the Web to not disclosure your personal information.
To save some disk space and server bandwidth deleting the EXIF thumbnail and some other tags gives up to 100 KiB off a size per each file.
When you do photomontage and combine several pictures into one.
The processing does not affect quality of an actual photo at all. ExifCleaner blazingly works with batches, can be integrated into the Explorer shell for quick access to its major functions, and compatible with all NT-based Microsofts systems, starting from Windows 2000 and XP, up to Vista, 7, and the recently released Windows 8 Consumer Preview (including 64-bit OS editions).
