PMN
- Paul
'Evening chaps,
Quick question regarding Epson scanners that hopefully one of you fine people will know the answer to! The V500/V600 are essentially the same scanners with the same performance as are the V700/V800 (apart from the lamps), but what's the difference between the two series of scanners? Is there a noticeable improvement in performance, particularly dynamic range and sharpness, with the V800 when compared to the V600? I'm looking to get another compact flatbed scanner to replace my tired V500 and am trying to figure out which one to go for, if the performance is definitely better then it'll probably be the V850 but there isn't really much point in spending the extra few hundred quid if the performance is largely the same across the board. Has anyone done any side-by-side comparisons?
Thanks in advance!
Thanks in advance!
