Oh yes. I've had some shots saved by the IS, the only thing (with my photography) that will let them down, is movement by people rather than camera shake.
i thought that the IS could only help with camera shake and not stabilze the actual moving objects you are trying to capture. please correct me if im wrong![]()
I chose the Is version simply cause the weather isnt too good in uk so didnt want to be limited, also IS version is weather sealed..
Okey Kokey, IMO youre wrong.
I own one of these, and imo the IS helps stabilize the moving object, for me 99% of the shots i take with it are panning shots and the IS locks onto the car/bike/sheep allowing my panning to not be 100% accurate and still get sharp results.
That's nothing to do with the IS - it's for lens/camera/user movement only, and is independent of the focus system - which is what is locking on for you.
Re the original question - if you are going to be situations where you be shooting at less than 1/300 (to be safe), for example inside, you will need the IS to get sharp shots at 200mm.
