HoppyUK
- Richard
- No
I use both a light meter and chimping depending on what I am trying to do.
If I want to set up three lights with a known ratio in order to reproduce a known setup I will use a lightmeter as it is just not possible using any other technique.
If I want to blow the background or check how even the lighting is in my hilite I will chimp it and use the blinkies.
If I want to ETTR then I can use either technique. With a lightmeter if I want to ETTR by one stop I can just lie to the meter about the ISO. With the camera you just open up the aperture a tad.
But in front of a client it is about speed and professionalism. They do not want me to take 5 shots to home in on the correct result. I want to be able to move a light/put on a different modifier and just meter the result - for this a lightmeter is perfect.
But as others have said it is up to the individual what they use. My advice is to learn to use all the tools and then pick the right one for the right reasons.
Truth is, that's what we all do
Sorry to bang on about ETTR, but it's not something you can do properly just by adding 'one stop' or whatever as a fixed increase, to the meter reading. The amount that you add depends on the subject and is variable - in my experience, between one and three stops. Which is why you need the histogram/blinkies to tell you exactly where you are with the important highlights.
I an convinced enough to get one to try properly simply to save some time.
Haha!
