D300 files uploaded wit Lightroom out of synch
NorthernNikon
Barney
As per the title, I'm experiencing some issues with my D300 files uploading with Lightroom out of synch. It tends to swap the first and second shots in a series of shots taken on high speed continous mode. I've not checked my memory cards but I suspect it's Lightroom that's swapping the images. Has anyone else found this?
I have the same issue but not just with the D300, I also get it with the D3 and it did the same with the D200. I've never looked into it tbh as it has never been too much of an issue but I have found that it often puts the last shot first.
Ah, so it's not just me then! It's just a bit weird going through shots of show jumping and seeing the horse go backwards!
No I haven't. Like Hacker said it's not the end of the world but I just wanted to be sure that it wasn't a fault with my D300.
Try changing the sort order, to file name, if it isn't that already. LR may be looking at the time stamp and getting it wrong.
Might be worth a try though, I think you can install it alongside your standard version of LR and try it out. At least you can raise the sync issue with them for the next release and fingers crossed, they may listen!
