Riz_Guru
- Riz
- No
lolSnip:
Exactly, there's not much point in wearing a belt and braces if a bulldog has just ripped the backside out of your trousers!![]()
lolSnip:
So what happened then? We appear to have a few seconds/minutes of footage then it breaks down. Doesn't the whole card usually corrupt if it goes bad? Was this therefore caused by some sort of camera malfunction in that case? If so, how would having 2 cards have helped there? Was it a dud batch of cards? In which case the likelihood is that they'd have had two of the same batch in the camera while filming that video.Except that's NOT what happened.
It can only be two real scenarios here...So what happened then, we appear to have a few seconds of footage then it breaks down. Doesn't the whole card usually corrupt if it goes bad? Was this therefore caused by some sort of camera malfunction in that case? If so, how would having 2 cards have helped there? Was it a dud batch of cards? In which case the likelihood is that they'd have had two of the same batch in the camera while filming that video.
Sometimes 2 cards aren't going to help. Should a camera like that have 2 card slots? Well, that's a whole different question.
So what happened then, we appear to have a few seconds/minutes of footage then it breaks down. Doesn't the whole card usually corrupt if it goes bad? Was this therefore caused by some sort of camera malfunction in that case? If so, how would having 2 cards have helped there? Was it a dud batch of cards? In which case the likelihood is that they'd have had two of the same batch in the camera while filming that video.
He didn't say 3 CARDS, it was 3 CLIPS. One card, 3 clips. 4m34s in
Sometimes you just get a corrupt file in the card. Or a few corrupt files. Or suddenly an error pops up and the card goes dead but you can only recover X% of the files leaving the others unrecoverable.
1- The SD card genuinely failed
2- The SD didn't fail and its a big store (lie) to generate more traffic
Either way, its bad press for the Canon R which seems to be getting a lot of criticism.
Ah, the joys of a fast moving thread and typing a post while others are doing the same! Thanks for explaining, I wonder what caused the fault then, as I said, I've never yet had a card go bad on me, and I wouldn't really expect this of a new card (unless someone brought an old one and used that?) in a new camera. I know anything can potentially break at any moment though, so no need for anyone to point that out.He says in the video at 4m34s. 2 or 3 clips didn't record. All cards run NAND memory. They also employ controllers for error checking and wear levelling. Sometime the controller fails (in which case the card is gone) and sometime some of the NAND cells fail. That sounds like what happened here. It's NOT a camera fault. So having a second card would mitigate against that unless that card was also faulty (hence the use of the word mitigate).
The linguistic gymnastics being employed here to somehow let Canon off the hook for this s***ty and deliberate decision are hilarious.
I would assume that if this happened in the presence of a Canon rep, then he couldn't be accused of anything underhand. Seems obvious to me.I'd still like to know why he was so pleased a Canon rep was at hand during the 'minded' field trip. I'm minded to think there are bits not being told here.
Except you can make some awesome really wide angle footage with the SonyAbout things that won’t matter to most photographers in the real world who don’t give a damn about 1.8 crop 4K, single card slot etc etc and just want to take some photographs that will be indistinguishable from those taken with the Sony A73 or any other decent camera. And the Nikon will be the same.
Ok so I've not followed all the posts but is it definitely a card failure and not that the file's not been written right in the first place? If it's the latter it wouldn't matter if it had 1, 2 or 10 card slots as they all would've had errors.
Also, am I the only one that seems to like the Northrups and Jared Polin's videos? Sure there's some nonsense in there from time to time, but on the whole they're pretty informative and done in a good way (IMO).
Nope, I quite like them too. Certainly better than that "Angry Photographer" tw@t.Also, am I the only one that seems to like the Northrups and Jared Polin's videos? Sure there's some nonsense in there from time to time, but on the whole they're pretty informative and done in a good way (IMO).
I think you guys are being to harsh. What have tw@t's done to be spoken bout like thattw@t is being generous lol
I like them both [emoji1]
Yep the DPR (former TCS) guy is good to watch. Kai from digital rev can get a bit irritating at times though.I do too though they can both be a bit shamelessly click baity at times and I cringe every time JP shoehorns the ‘dot com’ onto the end of his intros but both channels are very professionally produced and very watchable.
Prefer the DPreview guys (former TCS) though. Often very amusing, light hearted and down to earth and non of the hysterical click bait video titles. Their annual summary shows used to be brilliant.
I like Chris Niccolls, enjoyed his videos as the camera store and still enjoy them with DPReview. Not a fan of the Northrups, not keen on their presenting style, but their productions are usually professional .Yep the DPR (former TCS) guy is good to watch. Kai from digital rev can get a bit irritating at times though.
I think most of you are missing the point!
The card couldn't have failed as the video is there for us all to see (prior to there being no record). Subsequently 2 or 3 more SD cards didn't record. To my mind that points to the recording/writing algorithms of the camera. In this case it wouldn't have written to any other slot either 2x, 3x etc.
How many of us have had three or more cards fail simultaneously?
What is not recorded for us in this dubious review is how Canon managed to fix it! (It is noted there was a Canon 'minder' with them) Did they have a continuous supply of SD cards. Is it a bit like having fuses fail and keep changing them until one holds?
There is a whole part to this story which is not being told! (Unless I've missed something)
There are one or two Lexar cards in the market even though that company left the market,TN said one card failed, and that he lost three clips from it, video at 4:20.
That was not a new card (Lexar, pre-liquidation) so presumably it's been used before without problems, and he formatted it in the EOS-R. So far so good, but it would not be the first time that a new camera has had problems with certain cards at launch - presumably because it would be impossible to stress-test prototype cameras with every conceivable make, model, size and speed of all cards ever made - but it's always quickly fixed with firmware.
But it may have, and by only having one card slot no one will ever know. Better to have the extra slot option and choose not to use it than not have the option and something like this can happen.Who knows, but given all that it could simply be a new camera bug and dual-card slots may or may not have saved the day.
<snip>
But it may have, and by only having one card slot no one will ever know. Better to have the extra slot option and choose not to use it than not have the option and something like this can happen.You and others will choose to disagree, but I would rather have more options and features than less.
For having a card go bad on him!He's got a bad card, is his fault anyway...
I don’t understand Canon’s decision for one slot but Nikon are saying that they don’t have room for two XQD slots. This would make sense barring two things. Firstly the camera was built from a blank page so just make the camera a bit bigger, the EOS R is that little bit bigger than the Zeds and maybe making the Zeds the same size would allow 2 XQD slots. The second thing is why not an XQD slot and SD slot as that wouldn’t need as much space. Apparently their response was that it would slow them down as the XQD card is faster. OK, so what about the D500 and D850 that both have one XQD and one SD? Can’t help but feel like they come out with some bs sometimesActually, I don't disagree (even though I'm not that fussed personally). I think Canon made a serious and unnecessary mistake, but they did it deliberately to make a positioning statement re the new mirrorless EOS-R and their higher spec DSLRs, ditto Nikon Zeds.
What Canon (and Nikon) didn't fully appreciate was how a very vocal minority of wedding photographers and vloggers would react (again and again!). If any good comes from this, it could be that in future we'll not only get two card slots, but they'll also be to the same speed/spec.
Turn the volume all the way down and cover right side of screenI like the old TCS crew, now DPR but they seem to be continuing to do their videos in their own style. I think my problem with the Northrups is they come across more like Tv breakfast show presenters. And I hate breakfast shows.
I watched a video by them a week or so ago and Chelsea Northrup mentioned that she didn't want to be on camera when it all started but has slowly got more confident. I think they work well together, which you would hope for seeing as they are married.Quite like this presenter, makes a change from ranting lunatics, always comes across as a pleasant well educated bloke.
Think his missus could get a bit more outspoken if left to her own devices, but probably realises that would ruin the concept.
Can't see why they wouldn't include a second card slot, many of those in the know say its a good idea so it probably is.
