stevelmx5
- Steve
- No
Well that don't take long...
I'm not going to do any crazy conversions on the 1G because options are pretty limited (although I did see a video last night where someone's embedded a Sony digital compact inside a Leica ii body and it was a very neat job..). However, I keep picking up the camera and feeling like it's a bit too thin to hold comfortably. I'm not a fan of half cases at all so it's already out of the one it came with so my other option is printing a grip like the one I did for the Pen FT.
(I can't take credit for the 1G model I've built around!)
This is a rough estimate for depth, around 20mm at the deepest point so not huge but should add enough extra grip for comfort.
I've built in a 1mm indent on the face of it so I can bond a leather insert into it to make it a bit more comfortable than the hard plastic as well as making it blend in with the body better. I'll bond it to the original base plate with thin double sided tape so the base can be removed to load/unload film and also keep the grip attached to the body.
The only other feature I might include is a basic split ring so I can fit the same single finger grip I use on my other cameras meaning I can hold the camera securely with one hand.
