- No
I really don't want to go down the studio flash route again, and to be honest don't have the space for it, but would like some advice on continuous lighting.
I have a small area I am setting up in my room to one side of my bed for portraits, I will be shooting from approx 6-7 ft from the subjects, this is a fixed distance as I am permanently stuck in bed.
I feel flash would overpower in this situation and was thinking of a couple of small soft boxes one approx 5 ft to the right of the subject the other in front but approx 10 ft away.
Obviously I would like to be able to vary the lightings output to adjust the lighting to taste.
I plan on using a pop up background and train hung on the wall with a reflector hung to the left and used as either a reflector or with its black panel to kill light on that side.
I also need to keep things simple as I will be relying on my subjects to bring the lights in for me and position them.
* update*
Given whats been said, I have been looking at using 3 flash guns.
I already have one Nissin Di622, so was thinking I could add another as they have a built in slave function, then add a yongu cheapy to run at 1/8th power for background separation.
My only issue with this is metering.. I was used to my old set up and using a flash meter but would it be the same with this or would the ettl work?
I'm looking for a compact and hassle free solution to light this 1.5 x 3 meter area where the background will be but giving as good a results as possible lighting wise.
* solved it thanks to your input, going for another flash gun for now and an interfit S bracket softbox kit for it.
I'll make do with one gun in the softbox and connect via an ettl lead to the camera, use my 60" x 40" reflector on the other side to take the edge of the shadows and the second gun for separation from the background.
Later I can add another softbox and gun into the equation and the system also means I can use the snoots, beauty dishes etc from interfits range.
Power should be ideal given the small area and closeness to the subject, but I have fast lenses for portrait use and the camera will be on a tripod anyway.
Thanks again for the input and making me think before leaping.
* update*
