Hi, I am new here and not sure if this is the correct place to post this question....
I have a Canon EOS 550D. I have been learning photography since about last October and so far really enjoying it! My main area of photography I enjoy is motorsport, capturing the movement etc.
Although I normally shoot in TV I was experimenting with the camera last night and noticed there seems to be a difference between auto and AV (keep reading, not quite the silly statement it might first sound!)
Basically, in full auto when focusing on a set position (inside with stable lighting) the camera will default to....
ISO 400
5.6
shutter 1/60sec
flash fired
When I switch to AV and set everything the same I get the following settings...
ISO 400
5.6
1/4sec
flash fired
The question is, why when all variables are the same (ISO, flash, focus point, lighting and aperture) does the shutter speed selected by the camera vary between full auto and TV. Surely the overal output should be the shouldnt it or am I missing something?? The full auto image comes out looking good. The AV is a touch over exposed. Also when I change to full manual and select the full auto settings the image comes out the same as full manual but the incamera light meter is at the bottom of the scale! Is this normal for the 550d?
Thanks in advance for any reply to explain why the camera behaves this way.
ISO 400
5.6
shutter 1/60sec
flash fired
ISO 400
5.6
1/4sec
flash fired
