Collage photos
Bambi'sThumper
Jenny
Hello. I'm needing some help....
I'm wanting to make a collage of about 3-4 photos (in photoshop cs3) but i have no clue where to start, i'm really not sure what to do.
It's most likely the simplist thing but i cant do it!
I'm wondering if any of you lovely people could give me some tips on how to do it?
Thank you Jen :)
have a look at last weeks amateur photographer mag, its got a how to.
last months practical photographer (i think) also had a how to, however they demonstrated it on a subject that meant that the end result looked like a deformed child
Hi Jen ,
The best way to do it in photoshop is the use the mask function and then the gradiant tool to blend each photo into each other, I use CS 2 but all other versions should be the same.
Or simply select the picture press ctrl @ Q and use the brush tool to add or subtract the parts of the photos you want to blend ( have your brush quite soft as it helps keep the transition smooth )
Or use the microsoft program to do the work for you
Hope this helps
Kevan
